need reviews of this heater
Re: need reviews of this heater
When I searched on the net yesterday I found several mini splits with aux heat. I have two such units on the maids house.
Everything this side of the pond is 240 volt so that would not be a restriction.
Most all units have the small crankcase heater mentioned.
Many, if not all, have a defrost arrangement for cold weather for the outside unit.
Some units have the electric resistance heating in the event of too cold ambient temperatures. -
Russ I found a few as well. I posted these back a few. If you don't mind could you post any others you have found? I'm looking for around 9K singles or 18k multi's of which I've found only Sanyo ceiling units.
Thanks! -
Re: need reviews of this heaterRuss I found a few as well. I posted these back a few. If you don't mind could you post any others you have found? I'm looking for around 9K singles or 18k multi's of which I've found only Sanyo ceiling units.
Thanks!
I believe those Sanyo units are discontinued as they were R-22 units with SEER ratings of <13
You won't need the backup electric with a properly sized INVERTER unit unless your outdoor temps go below 5F for extended periods. If you do need the additional heat put in a several feet of electric baseboard.
Perform a heat loss calculation on your rooms to find out what your heat loss is at your design out door temp, and size accordingly.
remember electric heat has a COP of 1
inverter heat pump has a COP > 1.8
- 228 Forum & Website
- 618 Discussion Forums/Café
