Xantrex XW-6048 or (2) Outback GVFX-3648
keyturbocars
Solar Expert Posts: 375 ✭✭
Which is a better built grid tie inverter system for the long haul? Which is a better choice?
Xantrex XW-6048
or
Pair of Outback GVFX-3648
Thanks for your opinions, insights, and experience.
Edward
Xantrex XW-6048
or
Edward
Re: Xantrex XW-6048 or (2) Outback GVFX-3648
I vote for the XW. First because it is more versatile and second because I am have more experience with them. Both are good products but the single XW will be easier in the long run. -
XW-6048 for sure, the outbacks are outdated, not very efficient and have very limited features compared to the XW series
Also, the OB units aren't 3.6kw units ... more like 2700 watts, the higher rating is at 25C
The XW is a real 6kw unit with a true 12kw surge -
the xw6048 has true 240/120 split phase, I don't know what's needed to get this from the outbacks, just a sync cable, or sync & transformer.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks for the helpful feedback.
Edward
- 230 Forum & Website
