Power Factor Correcting power supplies on MSW Inverters
RCinFLA
Solar Expert Posts: 1,485 ✭✭✭✭
This is more of an alert thread. I was reviewing customer rating comments on computer components and ran across one that down rated a computer switching power supply because it blew out when he ran it from a modified sinewave inverter.
More and more computer power supplies are including PFC circuits. Many driven by country regulations.
Most PFC switching power supplies have a pre-switcher that assumes a sinewave input with a switching profile on the pre-switcher so it charges the main D.C. filter capacitor with a sinewave pulse shaped current profile. This gives the good power factor.
Applying a modified sinewave (modified squarewave) inverter can cause the PFC circuitry to go crazy and cause the power supply to fail.
Most small home computer UPS units use modified sinewave so they create a risk of damaging a computer PFC power supply.
Re: Power Factor Correcting power supplies on MSW Inverters
Very interesting. Thanks for the heads-up.
Some info on PFC here:
http://www.endpcnoise.com/cgi-bin/e/faqpfc.html -
I wonder if the passive PFC type devices are the ones that are failing... In general, I had understood that active PFC devices do OK on MSW inverters.
Re: Power Factor Correcting power supplies on MSW InvertersI wonder if the passive PFC type devices are the ones that are failing... In general, I had understood that active PFC devices do OK on MSW inverters.
Bill you probably hit the nail on the head with that one. Makes sense.
And I would have thought the opposite, as portrayed by the Iota power supplies, which will run down to DC. (they have about .65 PF.)Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Are you sure about the DC input for the Iota's? Generally this type of supplies have a rectifier diode and capacitor front end (reason for the poor power factor)... Yea, they may run on around 170 VDC--if they do not use a voltage doubler. However, I have not ever seen any normal supplies actually rated to do that.
Active Power Factor corrected power supply can generally run the same AC or DC voltage range on their input.
Yep, quite sure about the Iota running on DC. Simple diode/cap at the input, no PF circuit at all. 130VDC does not give full power output, that the peaks of the 120VAC suppliesPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Makes sense.
A supply with active PFC can run from ~95-264 Volts at 50/60hz or DC at full rating (or whatever their particular supported voltage range is).
PS: I would not suggest running at 120 / 240 non-PFC supply at the 120 VDC input range--The manual switch (and autoswitch) supplies use a diode/cap voltage doubler on their AC input... 120-170 vdc would never get the 300+ volts that is required to operate the supply.
-BBNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
