Impressed with Outback
backroad
Solar Expert Posts: 185 ✭✭
I've got a Flexmax 60 that's about a year old. It's screen is locked up and will not budge. I disconnected it's power source to "reboot" with no luck, so I called Outback and described the problem to them. No questions asked, they are just sending me a new one out today. I'm glad that I started my off grid system with the 15kw Perkins generator, as it's been great whenever I've had any kind of a problem.
Great customer service....I wish I had as good of experience with my Magnum Inverter. Oh well, life is great.
Re: Impressed with Outback
you're in bagdad?
How do you have internet?
The same question crossed my mind a few times, Till I saw a program mentioning it on UK TV a while back, Bagdad ( note the lack of an "H" ) AZ http://bagdad.arizona.com/
Tim -
Verizon is a mghty powerful thing and yes it is the Az version of Bagdad. -
What problems have you had with your Magnum 4448 inverter?
That's the one that I have seriously considered buying. -
It flat out quit invering. I had to pay about $50 to ship it to them after we diagnosed the problem over the phone. They said they could not find anything wrong with it and said I would have to also pay.for return shipping. I didn't feel very good about their customer service. When I got it back it worked fine. Very suspicious... i've had it for about two years and no other problems.
Re: Impressed with OutbackIt flat out quit invering. I had to pay about $50 to ship it to them after we diagnosed the problem over the phone. They said they could not find anything wrong with it and said I would have to also pay.for return shipping. I didn't feel very good about their customer service. When I got it back it worked fine. Very suspicious... i've had it for about two years and no other problems.
Sounds like the inverter has or had an intermittent connection and fixed itself during shipping. They always seem to throw things around quite a bit.
This is why I would give the unit a good (but safe) thump on the top and/or side to weed out a bad connection. If a unit cannot live through UPS or shipping, it has a problem (or the packing is badly designed)
boB -
Side note - re Thump.
I opened my Tristar MPPT this weekend, to connect the RS232 cable (got to find a better way before I wear the cover threads out) and found in the base of the unit, about a 2" piece of solder ! WTF ! I pulled it out, everything was still working OK, but where the he$* did a hunk of solder come from ? All wire is copper, not tinned, must have been a factory leftover, that fell down from somewhere.
So if I'd thump'ed it earlier, wonder where that would have settled ???Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
