Does any body use a UV sterilizer with a cut off switch to save electric.
beth
beth Solar Expert Posts: 32
Thanks again to all for answering my PV solar questions. I thought I would ask if any off griders are using a cut off switching system ( and possibly a water solenoid valve in conjunction with) to turn off their UV sterilizer when the water is not running to save electric. If so could you please describe it. Thanks
    Re: Does any body use a UV sterilizer with a cut off switch to save electric.
    UV sterilizers should have their own switch, because without water flow, the tube will overheat.
    I'm using a UV/ozone bubbler in the water tank (Triple O)
    I guess this is the company:
    www.tripleo.com
    But they only sell through dealers.
    Dave Angelini Solar Expert Posts: 7,081 ✭✭✭✭✭✭
    Beth,
    Why do you treat the water BTW?
  • Ralph Day
    Ralph Day Solar Expert Posts: 1,038 ✭✭✭✭
    I'm in that boat. I've used a Sterilte (12gpm uv light) for many years and even before being off grid I put it on a timer to save power. It comes on 15 minutes before alarm wakeup and shuts off 30 minutes after lights out (9:45pm).
    Some will say not to shut off the light, but I've never had a bulb fail from cycling, only old age. First bulb lasted 5 years.
    The solenoid is overkill I think. If you have a teenager come in late...just tell them not to use any water, or trip the timer.
    Ralph
  • russ
    russ Solar Expert Posts: 593 ✭✭
    All the UV lamps I have looked at specify a 1 year (8760 hour) life.
    Is that not true?
  • Ralph Day
    Hi Russ
    That's the spec for bulb life..especially if you're selling the bulbs. I check the bacteria count every 3 months (0), and clean the crystal the bulb sits in (not as often as I should), and have never had more than a zero count. Replacement every 3 years or so for me. THe water is soft (rain or softener-ed), but raw tests have some bacteria from dug well or cistern, so it's always going to be used.
    Ralph
  • beth
    I treat the water because I harvest rain water. I have heard as well that cycling the bulb on and off reduces its ability to produce strong UV something with the gasses inside the bulb. But I wonder if UV companies would rather its consumers keep their bulbs on 24 hours. But I am sort of thinking with a small unit that may be appropriate for me at 25 to 35 watts I may just keep it on. Still trying to figure this out. Thanks All.
  • Ralph Day
    Beth,
    How about buying an extra bulb (you'll need it anyway) to have on hand...trying a switch or timer and watching your bacteria counts closely. If the cycling smokes the initial bulb, you'll have a replacement handy, than change the on/off cycling if needed?
    Ralph
    beth wrote: »
    Just because you harvest rainwater UV is not the only way to make it potable. Your grandmother might not have had electricity when she was young.
    UV is a great way to treat water if it is needed. I use to do that myself until I found the data was not showing any benefit over the chlorine method my grandfather used. Just an FYI
  • System2
    System2 Posts: 6,290 admin
    We use a Trojan D max system in conjunction with a solenoid. We have lots of guests and don't want anyone leaving poorly. One low voltage switch controls our entire water system: instant hot water, pressure pump, solenoid and UV filter. To get through the night we use a precharged pressure tank after the solenoid to run the taps for hand-washing, etc. after bed-time. The 12v solenoid is operated at 7VDC to save power. The tank also acts a buffer when the sytem is turned on in the morning; avoids the possibility of water being used while the lamp heats up (about a minute or so).
    Regards
    Rob
  • beth
    Thanks all, I called sterilight (trojan) in canada they said an on demand system of cycling on and off is not good but shuting don at night is ok. I ll skip the solinoid and just flip a ball valve at night.
