Hole in solar panel
When I arrived at the cabin, I found that one of my panels has a small hole through it, much like a rock hole in a car windshield. The panel is still generating some power. If I just seal over the whole to prevent water leaking under the glass, is there any downside?
Re: Hole in solar panel
Well, tape sealed over the hole will help some, didn't the glass completly shatter, or is this a homemade panel ?
When vater vapor gets in and condenses (like in a wristwatch), you cannot get it out, and eventually the cells metal plateing corrodes and the panel is dead.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
You can buy a kit at most auto parts stores that's made to repair "bulls eyes" in auto windshields. It's made by Permatex and costs about $6 (last time I got one).
There's a syringe that adheres to the windshield and draws a vacuum, then fills the bullseye with a resin that hardens by exposure to ultraviolet light (sunshine).
Would this fix your hole?
Phil -
if the hole is too large that windshield repair kit won't work too well. look over this item from another thread.
http://forum.solar-electric.com/showthread.php?p=63245#post63245
- 234 Forum & Website
