6 July, 2010 east coast heat / power forecast
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
So, today seems to be a stressful day for the grid planners. Will they keep the power on ?
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: 6 July, 2010 east coast heat / power forecast
Heard on CNBC that there was a 6 hour outage in NJ yesterday. -
ISO New England looked like they were covered when I checked it an hour ago. Of course anytime the system is ramped up, that is usually when marginal components stop working, so I would expect that there will be equipment related outages. Generally as long as the grid operators have some notice, they can call in some additional plants to be on line.
