Pole Mount Recommendations
gpt
Registered Users Posts: 18 ✭
Hi, I'm looking at a Zomeworks 168 pole mount passive tracker that will hold 6-8 Suntech 270's. As the total amount of panels I want to install is 14, my question is is there a less expensive solution than buying 2 of these? Thanks
Re: Pole Mount Recommendations
Does it need to be a tracker ? What if you had 2, just offset 20 deg from each other? That's going to be a pretty big sail sticking up too. I'd suggest Powerfab, but I've got only a couple months on them, but they did hold up in a gusty wind last month.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Yes, it has to be at least a passive tracker. I'll look into Powerfab. Any idea how they compare to Zomeworks?
- 231 Forum & Website
