Morningstar New Suresine Inverters
Saggys
Solar Expert Posts: 189 ✭✭✭
I received an email from Morningstar Corporation that PV Magazine has a webinar on the new Suresine inverters from 150 watt to 2500 watt
12-24-48 volt input. Does any one know of more information on this subject? I am in the market for a new inverter and the 300 watt Suresine/Sunsaver MPPT that we have for our small system has been working flawless for the last 3 years, so a larger Suresine would be great.
Well, you can be assured you'll get a rock solid, well designed product from Morningstar. Time will tell but I wouldn't expect any less from them.
I dug around in the Morningstar website and found the specifications for their new products which also includes a new solar charge controller. Now to wait for availability and pricing.
The only downside I came away with is there is no built in battery charger in the inverter line up and no mention of conduit boxes for the inverters, -
This is big news. Which other reputable manufacturer builds, for example, a 700 watt 48v low frequency pure pure sine inverter? None that I know.
My average load is 140 watts, with occasional forays into 260 watts when my inverter fridge is first turned on. My 3000 watt Outback inverter uses 25 watts at idle. This one burns barely 9 watts. At 18x10x6 inches I can pack one in my backpack.
Well built, low watt, low frequency, highish nominal bank off grid solar is a welcome addition.
I’m hoping the prices are reasonable, like the venerable 300 Sure Sine was. Not for me but for the tens of thousands of tiny house, or low consumption, poor folk who may now be able to venture into off grid solar.I know these products may have been manufactured for industrial, Internet, or utility applications but they have the potential to expand access to off grid living in lots of ways.Bravo Morningstar.Outback Flexpower 1 (FM80, VFX3048E-230v, Mate, FlexNetDC) 2,730watts of "Grid-type" PV, 370 AmpHrs Trojan RE-B's, Honda 2000 watt genny, 100% off grid. -
I predicted this news 5 years ago…
https://forum.solar-electric.com/discussion/comment/369068#Comment_369068Outback Flexpower 1 (FM80, VFX3048E-230v, Mate, FlexNetDC) 2,730watts of "Grid-type" PV, 370 AmpHrs Trojan RE-B's, Honda 2000 watt genny, 100% off grid. -
I think they are high frequency, but incredibly reliable and made in USA, Exeltech makes hard wire-able inverters down to 600 watts. Pure sine super reliable. 8watt at 600volt, they make a 1100 watt version that is 10 watts without a load. They make them for assorted uses with a variety of inputs and outputs.Surfpath said:This is big news. Which other reputable manufacturer builds, for example, a 700 watt 48v low frequency pure pure sine inverter? None that I know.
Silly/stupid long life, they now post
21.5 Years MTBF
but I recall this is based on incomplete data.
and I think they still have a $100 rebuild policy, if possible. I just read someone doing this last year.True Sine Wave Inverters - 125, 250, 600, 1100, and 2000 Watts (XP) (exeltech.com)
They have doubled in price in the last 5-6 years;
Exeltech XP1100 24-volt 1100 watt sine wave inverter | Northern Arizona Wind & Sun (solar-electric.com)Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Hi Photowhit,I heard that the Exeleltechs were quite reliable. I believe they made the only big name 48v low watt inverter until now.
From the Morningstar Suresine new data sheet on their website:Overbuilt, industrial-grade low-frequency transformer
Hopefully the price is lower.Outback Flexpower 1 (FM80, VFX3048E-230v, Mate, FlexNetDC) 2,730watts of "Grid-type" PV, 370 AmpHrs Trojan RE-B's, Honda 2000 watt genny, 100% off grid. -
Victron and Cotek through our host NAWS has several 48 VDC input pure sine wave models that range from 250 Watts to 400, 500, 700, 1,000, 1,200, 1,500 Watt on up...
https://www.solar-electric.com/residential/inverters/off-grid-inverters.html?nav_inv_input_voltage=439&product_list_order=price
Not sure I would go with a 250 Watt inverter with 48 VDC input... But it is there from Victron for $119.01 -- That is a lot of batteries & cells to maintain. And need a "higher voltage array" + "48 VDC charge controller" too.
Photowhit,
I just got my XP1100 48 volt inverter back from repair and it is still $100 plus shipping to get repaired. They even sent me a warranty registration card and I am not the original purchaser! It came back with new hole plugs and clamps (that were missing) in a foamed Exeltech box as if it were new.
I installed the low idle kit about 7 months ago and I measured 11 watts. This is a 2007 model that ran 24/7 365 in our telecom building at work till November 2021. Pretty impressed with Exeltech service, but still very intrigued with Morningstar 1250/2500 watt models. The spec sheet claims they are low frequency design with a toroidal output transformer.
