My Schneider XW PRO 6848 is making a screeching sound
methane_tourist
methane_tourist Registered Users Posts: 2
I currently have 3 Schneider XW Pro 6848, 3 CC MPPT 80-600, PDP, AGS, 2 Fortress 18.5kwh and 19,000 PV sys.
Every time there is a small voltage fluctuation the Schneider seems to disconnect from the power utility grid and support the house Load by PV generated energy + battery support. Every time it tries to support the house Load it starts to make this screeching sound until it balances the charge and can connect to the power grid once again.
Video of the screeching sound:  https://youtube.com/shorts/4MXIbKzYuWc
Video of the settings: https://youtu.be/k5Ky8iZ2kB8
  • Photowhit
    I wonder if it could be as simple as a fan going out?
    I had a Prosine with a squeaky fan, it ended up dying and I had to replace the fan. With the dead fan, it would over heat above 400 watts and shut down.
    Likely nothing to do with your situation, just throwing out thoughts.
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 7,127 ✭✭✭✭✭✭
    Need alot more info! Where, when, who installed, did it ever work right, have you contacted Schneider?
     The grid disco and connect to grid on voltage change are almost always configuration settings that have to be right. XWP has so many more settings that it really is a big job to configure.
    Never heard that sound, what load is it powering?
    E-mail offgridsolar@sti.net
  • mkimid
    mkimid Registered Users Posts: 3
    I have similar issue with Enphase IQ7+ inverters also, actually, it has not happen one year ago, but, it start to happening recently,
    If see the frequency it will shaking also, I have been using after Enable Phase Loss Detection at my IQ7+ inverters. .
    After couple of months, the other problem happening, it is start to generating a huge humming noise when no load.
    I have sent my inverter into RMA after talk with technical support
