XW6048, MPPT60 Parameters to sell excess power to grid
Horacio060
Registered Users Posts: 3 ✭
I have the followings parameters values:
Inverter XW6048 MPPT60
Grid Support - Enabled Bulk Volts - 58.1
Grid Support Volt - 64V Absorb Volts - 58.1
2 Stage Charging Float Volt - 54.0
Sell - Enabled 3 stage Charging
Bulk Volts - 58.1 ReCharge Volt - 51.0
Absorb - 58.1
Float - 54.0
Please let me know if I have to change one of them.
Sometimes even we have a bright sun the MPPT60 shows they are producing 350Watts and almost selling 0 to the grid. If I turn off the 60 amps breaker of the MPPT60 and turn it on the production increase to over 3,500Watts and increase the watts sent to the grid. I have 16 360Watts PV's connected to 2 MPPT60.
Appreciate your comments
Absorb - 58.1
Float - 54.0
Your Battery voltage likely needs to be larger than Grid Support Volt
else how does your system get to the Grid Support Volt ?
