Designing Off-grid (line interactive) system combined with on-grid system
As far as I know, each MPPT controller channel, needs it's own PV array, scaled for the proper voltage range to match the MPPT circuit. MPPT's can't share a PV array, unless you use expensive HV-DC switches to "move" the PV to another MPPT.
Better quality hybrid inverters have fast transfer times, 8ms for the Schneider 6848 inverter
which weighs 125 lb (57 kg). Pretty substantial.
I believe it has several programmable relays that can be set to activate devices at certain battery states. Generally, once the battery is full, surplus power is sent to the Grid and reverse your meter
High RRD,
What you are trying to do is very possible, but using commercially obtainable equipment will be expensive and just not cost effective.
Here in France, the Government run EDF Utilities, limit all households to a maximum of 3kW feedback into the main Grid. However all equipment and regulatory procedures required by EDF to connect to their Grid become hugely excessive and expensive.
So here in France feeding excess renewable green power we generate back into the EDF main Grid is no longer encouraged.
So our excess energy we just control and dump load some.
To Get around these issues 'we have tipped the whole standard process on its head'. We have a main Inverter, that is by-directional, 48vdc to 230vac connected to a 48vdc battery bank, and our 19kW solar PV, Trackers, Arrays and roof mounted installations all use second hand GTI's that feed into our own Inverter created Mini Grid, this system is called AC Coupling.
AC coupling its far cheaper concept for regulating and harvesting your own energy, rather than loads and loads of very expensive DC charging and connection equipment.
I talk and show 'Off Gridders' the AC Coupling System, at First they think its complicated and are led to believe (by the commercial boys) that they need masses of equipment. I just love it when after a couple of hours showing and doing, their 'light bulbs' suddenly come on and they get it. yeah!
Our Philosophy for a green and sustainable renewable energy system ........ keep it........SIMPLE, ROBUST, and COST EFECTIVE.
Everything is possible, just give me Time.
The OzInverter man. Normandy France.
3off Hugh P's 3.7m dia wind turbines, (12 years running). ... 5kW PV on 3 Trackers, (8 years) .... 14kW PV AC coupled using Used/second hand GTI's, on my OzInverter created Grid, and back charging with the AC Coupling and OzInverter to my 48v 1300ah batteries.
In Romania the FeedInGrid phenomena is the beginning. In 2017 was adopted the law which define the "prosumer" (consume and produce energy max 27kwp installation, now 100kwp)The government started in 2019 a project in which on-grid systems on 3kw minimum get 3000eur subvention (for free) and you have to come with 10%. Well, in the beginning of 2021 the authorized contractors started to mount systems and since the 2021 summer they started to get money from the government. (so it took 2 years from application documents to get the money, probably if it weren't covid-19, it would have taken one year)There are some conditions for the applicants:- you cannot build the system in DIY style. Energy certified and agreed contractors are only accepted.You buy the equipment from them and when there are free money from government, the contractors increase the prices.- you cannot use batteries to inject energy in grid- you cannot modify the system 6 years- you have to keep the system working for 6 years- you are monitored for the same period of time (smart meter, remote)- you are qualified to sell the excess energy at average previous year production price, no taxes- after that, the system is yours for free, you can upgrade it, modify it.AC coupling idea was recommended to me by some of PV enthusiasts on SoftpediaForum.The problem is there are indeed devices which you can use for AC coupling but most comes from Victron and others brands which is way too expensive.On top of that, the "commercial boys" from Romanian market sells equipment which the market wants (On-grid, hybrid, off-grid, grid interactive off-grid).So, the bidirectional inverter which supports AC coupling is some sort of niche product.But I am wilingly to adapt to this solution if the cost is about 7000-8000E as I calculated previously.Another factor which limits the choices is the foreign market.Some buyers avoid to buy expensive equipment from outside the country. It is difficult to request service or return product in case of warranty issues.That's why I prefer to buy from a romanian seller which I can find/sue if there are warranty issues.Schneider Xantrex are a choice but:Connext XW6048 is ~4800Eur(with 4800 eur you can buy 3 expensive GTI with backup, or 5-6 off-grid inverters on 5-6kw power)add 2x Pylontech 3000US = 2760Eur (which is minimal I say)and 16 x PV 375W = 2430Eurand do not forget about the 5-6kw on-grid inverter which is ~1000Eur (medium priced)put some money for the accessories (PV fixing system, ATS-S/backuo box, AC/DC protection, cables...) and there is 12-14k Eur no labor included.Probably in France/Germany, 14k eur is not a big value because of 2000-2500 usual salary (monthly).But in Romania, the average salary is 700Eur. Those which have well paid jobs can earn 1500Eur, and these are the people which wants other things in life than eat, work, sleep, go party.Think about this, previously I was considering use of chinese inverters MPSolar/Easun of other clones because they are cheap.I already raised the budget for more reliable equipment (eg. Growatt).If I raise it more, the project will die before starting (my wife has a word to say when big expenses are to be done)
Newer battery based hybrid inverters allow AC coupling of GT Inverters.
Growatt 3kW is a high frequency inverter, not of best quality.
High frequency hybrid inverters are not bi-directional in the same way a low frequency hybrid inverter (heavy low freq transformer) is. A low freq hybrid inverter can continuously move from power pull to power push with just a slight modification to PWM control drive. Most HF hybrid inverters have to make a mode change which takes longer and is not as robust as low freq hybrid inverters. A LF hybrid inverter with GT inverters AC coupled can rely on battery to absorb a momentary back surge. A HF inverter only has HV filter cap to absorb a back surge.
You need to do all the system paths efficiency calculations to find out if you will save money running a generator on natural gas. Also, DC coupling for hybrid inverter grid push puts ripple current stress on batteries so you also should factor in longer term battery replacement costs. -
You got that right on the quality. Growatt currently under recall for electrical safety.. AC coupling is not best for batteries in a small residential app. Especially if you do not know the exact compatibility of all of the inverters. It is an easy way to kill a battery bank even if you are an electrical engineer.
The Op sited XW 6048 which has not been in support for over 10 years. The current replacement with a 10 year warranty is XW pro 6848 which is a low frequency design. XW input relays switch at less than 8 ms. XW always have since it was designed in early 2002 and sales in 2006.
There are 600vdc rated A or B switched devices from Schneider Electric / Square D that can switch an array to different inverters or 600v DC chargers. Schneider MPPT-100-600v can run 8.5KW arrays. You can tell I am a fan of the company. They will be there down the road.
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------Contacting Growatt Problematic?
With regard to getting in touch with Growatt, we had a comment last week on an old blog post from an Australian owner who had attempted to contact the company about an unrelated issue over a period of 48 hours via the 1800 support phone number. He mentioned that provided 3 options, all of which were directed to a full voicemail box. And this was before the recall was announced.
“As the phone is never answered you can’t talk to a person nor can you leave a message,” said the commenter. “My email for assistance has gone unanswered. (not replied to).”
I tried calling the number early this morning. While it was outside of business hours and the recording stated that, it also said if I would prefer a call back, to press 1 to leave a message. Doing that just resulted in the same recording being repeated – there was no option to leave a message.
It’s not a good situation at the best of times, let alone when a recall is active.
Hundreds of 8kW Growatt solar inverters sold in Australia are subject to a recall due to an electrical safety standards issue.
On Friday, the Australian Competition and Consumer Commission (ACCC) published a recall notice on its Product Safety Australia website concerning Growatt 8.2kW 8000 MTL-S inverters manufactured between 18 January 2021 and 26 February 2021. The units were sold/installed by several companies in New South Wales, Queensland and Victoria.
E-mail offgridsolar@sti.net -
I've got an offer for a system DC coupled way too over my needs and budget. Probably they were thinking "we got a reach customer".Conext XW+8548E 230V - 3342EurConext XW- MPPT60-150 x2? - 513EurPV 345W x15 -188EurExide battery 2V/850Ah x24 - 424Europtional control panel -236 Europtional gateway -538EurTotal ~18000EurThis inverter is quite good for what I need, still expensive.I started to look for similar inverters/chargers and consider AC coupling with a cheaper GTI.I've got some recommendation. Still searching.eg:Victron Multiplus 48/5000 - 1800Eurother GTI which knows comunication (Fronius) - 1300EurIs it enough 2 x Pylontech US3000 3.5kwh for the beginning or should I start with 3 or more modules?(3 modules will provide 37A (recommended) x 48V x 95% x 3 = ~5kw)I have another offer for PV CanadianSolar 375W - 151Eur (it is cheaper than the one with 345W)
