Wattage difference at controller
I have 5-100W panels on the roof of my RV with a Renogy 40A controller.  Everything has been fine until this week.  The controller is showing panels connected but only at 12.2-12.5 volts and 0 watts.  If I disconnect the wires, my multi tester shows 19-21V coming from the panel.  I have tried 3 different controllers now with the same result, no charge.  I have checked the connections between panels and each panel individually.  I cannot figure this out and am losing sleep trying to come up with the solution.
  • Photowhit
    Are you hooking up the controller to the battery first? This is generally required to establish system voltage.
    Are the batteries full and can't receive more charge? Though the voltage would indicate they aren't...
    Which model of controller?
    Sounds like all panels connected in series?
    Any current?
    To pull the panels down to 12.5 volts sounds like apem controller on a relatively discharged 12 volt battery back?
    As Photowhit says connect controller to battery first then connect the array.
    Bill
  • mcgivor
    My first thought is there is a bad " high resistance" connection somewhere in the common wiring that feeds the controller  which allows voltage to be measured, but can't pass any current. Assuming this is a PWM controller given the panel output voltage  being 19-21 VOC connect the array to a load such as 2 × 12V lamps in series to verify there's is actually output,  a digital multimeter is not the best tool for fault finding as they have extremely high input impedance, a load is needed to force the failure point into fault.
    Usually when there is a high resistance connection, there will be signs of heat damage, pay attention to all screw type connections with multi stranded wire, the strands have a tendency to creep when crimp ferrules are not used. Check all circuit breakers and or fuses with a load connected, as mentioned above, by checking for voltage across the device, there should be no voltage, ensure all connections are sound. As the fault is common to all the panels, I would start on the common wiring first,
    Should the system have an MPPT controller, there are different tests, details are so important when asking for help.
  • Photowhit
    m1noel said:
    I have 5-100W panels on the roof of my RV ...
    I went back to see why Bill thought the panels were connected in series. Saw the above...
    If your panels are connected in series you will need a MPPT type charge controllers, assuming somewhat standard 100 watt 12 volt nominal panels.
    Best Solar Panels For RV 2021 or Camper Van Buyer Guide
    If you have an inexpensive PWM charge controller, typical of this application, the panels would need to be wired in parallel.
    If you have a more expensive MPPT type charge controller, they can be connected in series.
    edited June 2021 #6
    I was wondering if in series because of how "easily" the array voltage was pulled to 12.5 volts... And if there was a single "bad connection" or bad panel, that would also account for "crashing" to 12 volts and zero amps... In parallel, a single connection fault at the panels would not do this (unless is was from combiner to controller).
    Admittedly, that is a weak argument... But why I raised the questions (PWM, MPPT, Series or Parallel, etc.).
