Waterproof electrical housing for charge controller and inverter question.
GoldpanTam
Registered Users, Users Awaiting Email Confirmation Posts: 2 ✭
Hi All,
I'm a newbie. Please don't laugh at my system LOL. I started with the Harbor Freight 45 w solar panel kit. I have just upgraded to the Renogy wanderer charge controller. I have the harbor freight 700/1000 inverter and a 100 amp hour battery. I was using the system to power a tv, roku and charge cell phones in a tiny house I built out of a 20 ft refrigerated shipping container. Now I want to move the system and hook the battery up to a small camper and run the inverter to the tiny house. This is just for a mountain getaway I use about one weekend a month. So here is the rub. This needs to be portable. I was thinking of mounting it to a metal wheeled cart that I have and I want to use a waterproof electrical housing. Has anyone ever done this or is there any down side to something like this? I was looking at outdoor wifi housing boxes. My first thought is always fire. I would love any suggestions as to what you would do if on a budget. Thanks in advanced. Also, would a system this small need a fuse? The inverter does shut off at high voltage as a precaution.
Thanks!
Gold Pan Tam.
Thanks!
Gold Pan Tam.
I built something like that, for power (recharge tools) at burning man in 2000
I made the cart/dolly separate, so the power station would not "walk away" easily
Batteries in the bottom provide ballast, wind never blew it over in 10 years
( yes - thats a Unisolar 60w panel )
It's no problem leaving the batteries(other than lithium in sub freezing), charge controller and inverter outside. I always have. 18+ years. Even in my fixed locations.
You can just use a heavy extension cord to run the AC power to your house. I used the same Ship-to-shore cord from my sailboat for the 8 years I lived in my cabin, though I did wire it into my breaker box and hard wire it to the inverter. With light loads you could just plug it in!
Picture of my battery box/power center.
You might google "solar generator" for some more ideas like Mike's, which is pretty darn slick! Keeping batteries warm is always a good idea, as temperature can affect capacity quite a bit.
The 45 watt kit from Harbor Freight uses thin film panels which are much less efficient than crystalline panels. You can replace those panels with a 100 watt monocrystalline panel which is smaller and has more than twice the output power. A win-win in the portability dept.
Can't find the pix I wanted but along with all the others here a trailer is great. The one I did had the trailer level on on some bricks. The array tilted up to get to the batteries and electronics. It was for part time house building for a client. We got 1kw on the trailer and some golf batts. When they left the site the trailer just went into a locked steel shed and on a brick mount, stayed level.
E-mail offgridsolar@sti.net -
OMG These ROCK you guys. It's giving me a ton of ideas. Thanks for your time and comments.
