marine charge controller
Danmc
Registered Users Posts: 4 ✭
Type your m
essage
Hi, new here, and hope I am not offending the intentions of the group. I have an Arco M65 panel on a sailboat , that runs ( or did) to a Sun Selector M8 charge controller. The panel wires ran thru a water proof 2 pin connector which corroded or failed. I cut the wires from the panel so I could remove it, and yes, I marked them so I could id pos and neg. Unfortunately, don't laugh, I could not resist taking the Boing ( ? ) connector apart to see why it failed ( one the pin sheared off) , and then realized I had removed any way, for me, to identify which wire was pos/neg. The installer had used 2 white wires from the connector. Anyway, I think I sizzled the controller when I went to hook up the panel, so I think I need anew controller. I get juice from the wires going to the battery, but the lights on the controller showing analyzing, charging, etc, are not lighting. I want to replace the controller, but simply connect the new one to the wires leading to and from the existing controller. The existing controller has 2 orange and one brown coming out. I think each orange goes to one battery in my 2 battery bank, wired in parallel. There is another 2 batter bank, but that is, I believe, the starting bank. I also have a selector switch with Off, 1, both, and 2 on it . The Company making the old controller is out of business. If you have stopped chuckling, and can recommend a charge controller please let me know. The arco panel says 43 watts, max 3.68 amps, max volts 20, 5 amp fuse. Many thanks for any suggestions. Dan McElwreath
Morningstar solar makes some small, marine rated controllers.
https://www.morningstarcorp.com/products/sunsaver/
Midnite's Brat has water proof connections and unit, not real cheap at $75, says discontinued, but they have a current model of the brat I think.
https://www.solar-electric.com/midnite-solar-mnbrat-discounted.html
Specialty Concepts - ASC still make one unit, and still make them for others integrated (like gate openers and electric fences)
I used one for an early system and it actually had contacts in a little clear case, after a couple years I bought another for my boat with the new encased contacts like this one; I put the other one with a 40 watt panel on my dads pontoon boat and it lasted another couple years even with the open contacts.
EBay listing some might already be gone, but I think he's saying it's working and $16 delivered with eBays money back if he doesn't honor his agreement;
https://www.ebay.com/itm/Specialty-Concepts-ASC-12-8-A-Battery-Charge-Regulator-/184316893933
