Used Solar Panels
1popeman
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
Hi, I am here to ask questions about used solar panels. I was given 30 used solar panels. I know that solar panels have improved since these panels were made. I have tested the voltages on all of the panels and they are @ about 95% capacity.
Here is my question, since these panels work fine and they are free why not use them?
I also need to know what inverter to use. The array has a combined output of 7500 watts. They are KYOCERA KC167G panels.
I want to use these panels on a house on Kauai.
Any information is appreciated .
Tom
Tom
Those are pretty old panels. Kyocera makes a great product though. Off grid they should be fine. If you are planning on a grid tie system, there may be problems with used equipment. You will not qualify for any Federal tax rebate.
They appear to be UL certified, shouldn't be any problem for any type of installation.
Checking the panels by sticking a meter on them without a load, you are looking at the VOC numbers. I don't doubt that they are fine though. Looking at the numbers I would assume they are 48-54 cell panels. These were originally intended for grid tie, but work great off grid with MPPT type charge controllers.
https://americas.kyocera.com/press-releases/press-releases_20150319386.htm
- 222 Forum & Website
- 130 Solar Forum News and Announcements
- 194 Solar Information links & sources, event announcements
- 890 Solar Product Reviews & Opinions
- 254 Solar Skeptics, Hype, & Scams Corner
- 427 Caravan, Recreational Vehicle, and Marine Power Systems
- 815 Wind Power Generation
- 613 Discussion Forums/Café
- 306 In the Weeds--Member's Choice
