Charge Controllers
stmar
Solar Expert Posts: 373 ✭✭✭
I may be in the market for a new charge controller. My present one is a Morningstar PS-30, about 20 years old and I think it is a Gen 2 PWM type. I would like some suggestions on type, MPPT vs. PWM, brands and models. My system:
Schneider Conext SW4024, Combox, SCP
4 X Lifeline 8D 12 volts AGM battery bank, 24 volts
768 Watt solar array
And the aforementioned PS-30 charge controller.
Reason for thinking about changing is to get more flexibility in my charge settings.
You cant go wrong with Morningstar. Their MPPT controllers are rock solid. Maybe go with a 45 amp version if you want to expand a little.
There is always the Schneider 60 150 MPPT which will compliment the existing equipment by being able to communicate, it is perhaps overkill given the small array and is definitely not the cheapest option. Morningstar is good gear, the TS line is an excellent choice available in both PWM and MPPT.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 231 Forum & Website
