Project electric cooking for rural zones
DavidSerra95
Registered Users Posts: 1 ✭
Hi everyone!
I have been reading and learning from you for a while, today I would like to raise some doubts that are coming up with an NGO project that I have to present at the university.
I am studying whether it is feasible (now or in a few years) to make an off-grid system to replace the three-stone fire stove (since we are talking about rural areas) with electric stoves.
I have a daily consumption of about 2500 Wh / day and most would be a consumption contributed by the batteries, since the time zones of the food are at sunrise and sunset.
My first question arises if a 24 or 48 V system is preferable for such consumption (The maximum load power is about 2 kW).
The next question is with the batteries ... you cannot have constant maintenance since there is no training (they are rural areas of Rwanda), in this case, even if they are much more expensive it is better to use lithium batteries rather than lead deep discharge?
And the last question that takes me on the path of bitterness, I don't know if I should use an MPPT controller, PMW or use a hybrid to make the installation more compact and simple to use ...
I know there are many doubts, you don't have to answer all of them, any opinion will be appreciated.
Thank you very much for your time. Greetings and happy week!!
Welcome to the forum @DavidSerra95
Firstly it must be understood that solar power is extremely expensive, especially when it comes to heating 'cooking", outside the prime "midday " window of opportunity. Cooking within this window is possible which means there would have to be adjustments in traditional habits, good luck with that.
A better approach would be to look into bio gas generation using animal, or human waste, for that matter, to generate methane for cooking, then using the solid waste as fertilizer to grow food in a closed loop system, a friend of mine dose this using pig manure here in Thailand.
For now I won't elaborate on the details of why solar is not the best choice other than to say it takes knowledge as well as hands on expertise to manage a ballanced solar system, batteries are the archhillies heel, followed closely by traditional habits.
LPG would be a simple solution if available, however bio gas is a free source of energy once the infrastructure is assembled, which is actually rather simple and far less costly than solar......food for thought.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Hi David,
Let's say that all of they typical answers to the cooking question are not available (no local wood, fossil fuels not available, etc.). And that a mid day solar oven is either not a good fit (local foods are not oven based) and/or that this does not address the morning/evening cooking/heating of food to match the local workday.
Next, assume that the location is pretty sunny (3 or more hours of noontime equivalent sun per day. Typically closer to the equator/desert regions vs towards the poles/marine environments (like North East, UK).
And since time shifting of heating energy is needed, battery based system required (more or less, adding batteries will increase the cost of the system by 4x or more for batteries, charge controllers, etc.).
Li Ion vs Lead Acid batteries... LiFePO4 batteries are much lighter, more efficient, no maintenance, in some ways more forgiving than Lead Acid (and other ways, much more sensitive to poor operation) and less environmentally hazardous (if there is no local recycling of lead). However, they are 2-4x more expensive per kWH (at least) of storage vs Lead Acid. Li Ion batteries are not very recyclable (going to end up in the local dump). Lead Acid batteries are cheap, heavy (not a problem for a fixed home typically), Flooded Cell batteries need distilled/or very clean rain water (anything else will "poison the cells"). Lead Acid are highly recyclable (assuming local infrastructure available), and can be locally made (low tech manufacturing, although lead is not an environmentally friendly element).
Next, will do a relatively conservative design based on 2.5 kWH per day energy harvest, and 2,000 Watt peak load. This is probably 2x the battery required because conservative design... Make your own adjustments as needed.
Loads drive the battery bank size...:- 2,500 WH per day * 1/0.85 AC inverter eff * 1/24 volts * 2 days of stored energy * 1/0.50 max discharge for longer battery life = 490 AH @ 24 volt battery bank
Note that the battery bank also has to be sized for the maximum power draw... Typically that is ~500 Watts per 100 AH @ 24 volts, or:- 490 AH * 500 Watts * 1/100 AH (at 24 volts) = 2,450 Watts max continuous load (for FLA batteries)
Then sizing the solar array... Two calculations are needed. One based on the size of the battery bank (larger battery bank needs more charging current). And the second will be based on energy per day needed and hours of sun per day.
For charging lead acid batteries, 10%-13% minimum suggested for a full time off grid system:- 490 AH * 29.0 volts charging * 1/0.77 solar panel+charge controller derating * 0.010 rate of charge = 1,845 Watt array nominal
- 490 AH * 29.0 volts charging * 1/0.77 solar panel+charge controller derating * 0.013 rate of charge = 2,399 Watt array typical "cost effective" maximum
http://www.solarelectricityhandbook.com/solar-irradiance.htmlMadrid, Spain
Measured in kWh/m2/day onto a solar panel set at a 50° angle from vertical:
So, array sizing based on loads:Jan Feb Mar Apr May Jun 3.43
4.19
5.27
5.25
5.46
6.15
Jul Aug Sep Oct Nov Dec 6.40
6.26
5.59
4.22
3.35
2.98
- 2,500 WH per day * 1/0.52 off grid AC system eff (lead acid, AC inverter) * 1/3.0 hours per day sun (winter) = 1,603 Watt array "break even" December
And there are always the question of who will be running the system... The person who bought the system (you for your home in Spain), vs a NGO donation to a poor village elsewhere... The larger the battery bank and solar array, the less day to day work needed to balance energy used vs amount of sun available...
You paying for system, you will watch like a hawk--It is very easy to "murder" a battery bank by undercharging/over discharging. In 3rd world situation, the user will simply use all of the power they can until the system "goes dark"--And start again the next day--A good way to "murder" most battery banks/systems.
For larger systems (this is a larger system), MPPT system are usually chosen. Generally, they are more flexible (matching solar array to battery bank more efficiently). Also, the higher working voltage of the array allows the array to be placed 10s to several hundred meters away from the home/battery bank. PWM system are typically smaller, use more expensive solar panels, and array has to be right next to the battery bank.
I will stop here and let you review and ask more questions. The above is a very conservative/workable system... But not the cheapest solution.
Using resistive heaters vs something like an induction burner is interesting--But Induction burners are not really a good 3rd world solution. AC inverters run resistive heating pretty well. If you could find 24 or 48 VDC electric pots/pans for cooking--Would be nice, but not that common. Many other issues for choosing higher voltage AC vs DC battery power too... Even adding the cost/complexity of an AC inverter.
I will just add that as long as there is someone there who can manage low energy use and the funds are there, this is doable. There are many ways to do it.
In general rural folks need alot of education to do this long term without failure. Good advice above also."we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net -
I wonder if the OP has any notion of the value of the information that he received here "free? " I suspect that he appeared quite savvy when presenting this at his university.
I always have more questions than answers. That's the nature of life.
