GC2s and 8Ds are East Penn at Sam's
softdown
Solar Expert Posts: 4,062 ✭✭✭✭
Johnson Controls doesn't make all the FLAs. Guess I'd rather have an East Penn GC2 though I don't know the particulars.
Interesting because I'm pretty sure that WalMart sells Johnson Controls lead acid batteries.
Sams's club selection use to vary by region.
From what I recall the 'duracell' 6v gc were Penn and the 'Energizer' were Johnson Control.
Correct - they dumped the Energizer 8D in favor of the Duracell 8D a few years ago. It really seemed like the Energizer/Johnson Controls 8Ds were deteriorating in quality as time passed.Photowhit said:Sams's club selection use to vary by region.
My newest 9/19 8D only yielded 12.4 volts and will take a few days to charge at 4 amps. A small disappointment in what would appear to be a faster self discharge rate than I'd like. The other choices were 8/19. It appears their turnover is slower than they would probably like.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
