Problem XW6848
corto
Registered Users Posts: 4 ✭
Let's see if my XW6848 can help me at the moment only the panel is turned off and of course if it is in operation the house turns off I measure voltage and it has 51.6, I measure in the batteries they have the same voltage when removing the covers the cards are turned on but the panel no. I turn off the breaker of 250 of the batteries and when I turn it on a while it turns on the panel and it works without problems until it returns and it happens only happens in the inverter the controllers remain lit to someone it has happened.any suggestions
thanks jose
thanks jose
I wish I could understand what you are saying.I understand ( I think I do ) when you have 51.6V on the batteries and you turn the breaker on, the xw6048 works , but then what happens that makes it not work ?What is battery voltage when it's not working ?What are the cards ( when removing the covers the cards are turned on but the panel no )What is the panel ( when removing the covers the cards are turned on but the panel no )Any alarms or warning on the SCP or combox ?Does it fail daytime when solar is charging the batteries at 56V ?
He turns off sporadically, I turn off the breaker, and then he works until it happens againWhat is battery voltage when it's not working ?51.2 or 57 v when chargingWhat are the cards ( when removing the covers the cards are turned on but the panel no )Cards inside see ligth on for example card for connection xambus and where you put SCP and panel front the inverterWhat is the panel ( when removing the covers the cards are turned on but the panel no )Front the inverter ligth ac and baterry porcentAny alarms or warning on the SCP or combox ?Thats is the problem nothingDoes it fail daytime when solar is charging the batteries at 56V ?
yes any time -
Are you in search mode? Do you hear the inverter in a quiet room when it is not working? Do you hear it pulsing on/off?
next if not in search,
On SCP, select system settings, scroll down to view fault list Scroll Down to warning list. Are there any recent faults or warnings?
E-mail offgridsolar@sti.net -
Hi thanks for you help
search mode is off no used
When inverter off is heard off
no any alarms
when it turns off you can't see it in the scp you only see the MPPT 150
i measure voltage fluke multimeter power is 51 or above -
Look at these picture
Temperature cable is not connected i know it goes to the side
How old is xw6048? Sounds like it may be a warranty issue. Did it ever work correctly?
You are saying that 120/240 vac goes out to the house when this happens correct?
Have you tried removing DC from the inverter for a few minutes? There needs to be zero volts on the red and black battery terminals in your picture. Solar must be zero volts.
If this was a working system and this is happening it could have been caused by lightning.
You could also try restoring defaults in 6848+. Also make sure none of the advanced features got turned on by a nearby strike.
If you had a combox, gateway, or config tool you could try reinstalling firmware."we go where power lines don't" Sierra Nevada mountain area
- 231 Forum & Website
