360w chipped b grade sun power solar panels vs 340w A grade ones. Price is same
rollandelliott
Solar Expert Posts: 834 ✭✭
suntan solar, reputable company, is offering 340w a grade OR 360W b grade solar panels for same price of $110 no warranty made by sunpower. These are commercial solar panels with 6 rows of cells wired so each row is separate. So a chipped cell would only lower output in that specific row I think. company sent me sample photo of what a chipped cell might look like (just example, not actual panel)
I am leaning toward the B grade 360w cells unless someone suggests otherwise. San Tan claims no drop in power output, but they really dont' back up the panels with a warranty either.
Chipped cells as you show, develop micro cracks along the edge and those invisibly spread into the body of the cell over time, causing degradation. Think of it as a 5 year panel.
well it would only save $220 going with the B grade panels, so I'm getting the A grade, thanks.
Probably a wise decision, the margin simply isn't there, 30-50% would be worth thinking about,rollandelliott said:well it would only save $220 going with the B grade panels, so I'm getting the A grade, thanks.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
