solar
Plucka
Plucka Registered Users Posts: 130 ✭✭
I have two connected in parrallel 180 amp/hr lithium batteries which are fifteen months old and balanced with a battery controller which has room for three batteries.I tried to buy a third battery from the same supplier but was told he doesn't make 180's anymore and he offered me a 160 instead.What would be the outcome if I bought the 160-re problems.
    Practically, not much more than 10% difference... Usually not a big deal.
    What does the battery controller Mfg say? If they balance/control based on cell voltage (and assuming the cells are same construction), then probably no big issues.
    If the battery controller actually measures amps and amp*hours per string, then you might have an issue if the strings are not individually programmable for capacity.
  • mcgivor
    Assuming each has its own BMS, the BMS would protect each battery from overcharge or discharge. Using conservative levels of capacity, say 20% to 95% the difference between them would likely be negligible, but do confirm with the manufacturer if possible.
  • Plucka
