Two battery sources, one DC circuit
stmoloud
stmoloud Registered Users Posts: 111 ✭✭
I'm sure this has been answered elsewhere on the forum so easy answer would be if someone could paste a relevant link. I did try.
I have a power switch which I switch off when I exit the RV for any prolonged time. This cuts all DC, but unfortunately also to the radio presets.
I have a spare 85 ah battery which I believe I can use to back up the radio preset memory so have tapped into the radio DC input with a diode on the positive feed.
I have a voltage on the 'backup' battery of 12.6. If my main supply of 225 ah drops below this 12.6 v is it possible then that everything on the DC circuit is then supplied by the backup and not the main? At that point the backup will have a higher voltage of the two but I'm not sure if available amps will have an effect.
760W panel array, 4 x 6v 220 ah Crown batteries, Tristar TS-45 PWM controller,  no name 600 PSW inverter.
  • Estragon
    Not sure how the diode fits in.  Depending on the diode, there may be a material voltage drop across it.  You can get relays (ACRs) which will combine batteries/banks in parallel for charging, and separate for running loads.
    On my boat, the radio +ive bypasses the switch and goes directly to house bank.  As such, it keeps presets during summer use season.  I lift all circuits at the battery for winter, so no parasitic load from the radio during winter storage.
    Off-grid.
  • mcgivor
    edited November 2018 #3
    The current needed to keep the presets is probably miniscule, leaving the radio connected directly to the bank would probably have no significant drain, over a short period of time.
  • Estragon
    On mine, the load for the radio is okay for a few weeks, but gets to be significant over many weeks or months.
    Off-grid.
  • jonr
    IMO, you want a float charger (could be solar) on flooded lead acid batteries anyway.  AGM would be different.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,186 ✭✭✭✭✭
    Having a hard time finding one, but they make a small back up power supply that plugs into the cig lighter/power port that is powered by a 9 volt battery. It's supposed to be used to save presets and such when removing the battery. Might work for you, provided there are no other loads than the radio's clock and presets. I believe I found one in a auto supply like Pep Boys.
  • stmoloud
    edited December 2018 #7
    @littleharbor2 Yes have heard of these, they are supposedly not very long-lasting.
    Anyway, having some sleep on this I have managed to find a solution to the radio preset problem and also now have an emergency back-up system using the 85 ah.
    The radio itself requires only about 500 mA so I have a 1 amp trickle charger on the battery. The voltage to the radio is routed via a switch, one side of which is a diode prior to the radio input of the 225 ah source. The voltage from the 85 ah supplies the radio  but goes no further into the dc system. The presets then are always preserved whatever is the voltage source.
    Furthermore, the other side of the switch is used to bypass the diode so if need be the 85 ah can supply the whole dc system.
  • Ralph Day
    Ralph Day Solar Expert Posts: 1,038 ✭✭✭✭
    Ha!  I put a dedicated on/off switch on my rv radio circuit.  Even turned off it was the most annoying night light. Usually where we camp there's no radio I want to listen to either.  A gorilla tape flap covers the led's on the fridge...I like dark for sleep.
    Watch the "cheap" 1 amp trickle chargers... They (for me) have a tendency to boil the batteries dry (over charge, over gas) if I don't check the electrolyte levels every few months.
    Another issue is I had a dead battery and used a cheap trickle charger (1 amp @ 12 volts)--And while the battery did charge (to move the car), the trickle charger overheated and popped the case apart (dead battery drew more current than charger could safely supply)...
    Instead, I now use the more expensive "float chargers" and never have had to add battery water (I use them for cars/trucks that are not driven very often)...
    https://www.amazon.com/gp/product/B005EKY1EM
    BatteryMinder and BatteryTender both seem to be good brands:
    http://www.batterytender.com/
    http://www.batteryminders.com/
  • stmoloud
    @Ralph Day Me too I try to avoid led's in the bedroom. But outside of there in other areas it reminds me a lot of Christmas. There's so many they do concern me what their cumulative draw might be.
    @BB. If drawing off at the same time of charging the tendency would be for the charger to always to be on charge mode and maybe never get to the float of of 14.4 volts?  At the moment the charger is putting out 13.55 v and it is quite warm.
    I was considering hooking the battery up to my 10 watt solar panel but it putting in  580mA  max would probably not be sufficient.
