No panels yet. Generator to Batteries to Inverter to house?
Giovanni
Registered Users Posts: 1 ✭
Hi, it is my first post here, im writing you from Parallel 38º at the southern pacifico coast in Chile.
Im a young architect and Im finishing my own house. It is located in a rural area next to the sea and Im working on bringing Water and Electricity to the house but it is a long and expensive process.
I have read as much as I can about living off the grid and I've tried hard to setup a system that suit my needs but I don't have the knowledge to do it so I hope you guys can help me.
As an introduction to the specifications of the house I can tell you that the walls are build entirely with SIP panels of magnesium Oxide with 125mm. (5 inches) of EPS and the roof is made with steel SIP panels with the same insulation. The floor is a concrete slab also with EPS insulation.
I haven't calculate the electric load of the house, but the floor has an underfloor electric heating mat. Our plan is to use only LED lights, we have 2 heat exchangers for a future pool and the hot water inside the house is heated by a 50 Gallon Electric Water Heater. We also have an electric kitchen, oven, microve, a quite big refrigerator, 2 TV's, 2 computers, washing machine, plotter and the house has movable terrace and others mechanism operated by 12v winches.
I need to move to the house as soon as possible. The water is not a big issue because I have 5.000lts (1.320gallon) reserve, I collect all of the rainwater from the roof and I can easily refill those tanks with fresh water if needed.
My main problem is Electricity, The company is taking forever to bring electricity to the house and I cant wait for them, so I found recently some cheap batteries and bought them.
So... So Far I have 16 batteries 170Ah 12v
https://www.osibatteries.com/p-2275-enersys-powersafe-sbs-170f-sealed-lead-battery-12v-170ah-front-term.aspx
I also have a Kipor Diesel generator KDE 6700TA
http://www.kiporuk.co.uk/diesel-generator/kde-6700ta-400-64-67.php
My plan is, before buying the solar panels, is to connect the diesel generator to the batteries, the batteries to an inverter, and the inverter to the house.
I would like to buy an inverter that I can later use when the setup is completed with solar panels, charge controller and the company electricity.
I still need to finish the house, I don't want to buy cheap and useless equipment, but I need to be very careful with cash flow so I need to build my solar equipment with time.
In the beginning I don't need all of the electrical amenities of the house, just the basic stuff to move in, later, with the company electricity I plan on using everything electric.
1) Can I connect the diesel generator to the batteries, the batteries to an inverter, and the inverter to the house.?
2)If the answer is yes, which inverter do you suggest me for my needs? My plan is to extend my battery bank in the near future to at least 24 units of 170AH 12V Batteries.
3)Which charge controller do you suggest me to get?
4)How many solar panels should I buy in the near future? which brand and type do you suggest me to get?
I will share some pics of the house and the location so you get a better idea of it, thanks in advance for your time, hope you can help me with guidance.
https://player.vimeo.com/video/287935065
Its working OK now
PD. I know it is not a good practice but I really need some internet help on this one, so you may found this as a crosspost on other forums.
Its working OK now
Giovanni,
Just to let you know, your post has been approved... It was put in a que to check because of links and photos.
Should not happen again...
Now to read your post.
-Bill "moderator" B.Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
Definitely go with a 48 volt system. Even with that you will have 4 strings of batteries. In the future, if you plan to continue to use batteries you should use 6 volt or even 2 volt batteries. You can assemble a battery bank without multiple strings.
For sure, a 48V system with all your electrical loads.First question. What mfg / gear can you get in your area. Will you be importing or buying only domestically ?Inverter : a hybrid inverter, works with Grid or Generator powerMy suggestions: schneider-electric an international electrical supply company.and a couple electrical boxes and wiring to the generator. It will charge the batteries from the generator and then run silently off the batteries at night. When you get PV panels, they charge the batteries via a Charge Controller.
