Solar pv battery matching
mopei
Registered Users Posts: 1 ✭
Hi guys am new here ,but i need some.of your help
I have 2x250w 36v max systwm power voltagea solar pannels.
I want to charge a euro deep cycle battery 200ah.
So is it capable for me to charge with a normal 30 amps charge controller to charge a 12v ,200ah euro deep cycle battery ?
Welcome to the forum mopei
With the two panels the maximum current would exceed 30 A, 500 × 0.75 ÷,12 = 31.5A, this value will vary depending on battery voltage and panel temperature, so just a rough guide. The type of controller would need to be a maximum power point tracking, or MPPT, to reduce the voltage to the needs of the battery around 11-16 volts, a 40-45A version would be better suited for the task.
This link has some very useful information which may answer many questions https://www.solar-electric.com/learning-center you are however free to ask questions , many here are willing to provide guidance.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
