multiple small pwm charge controllers on 48v bank
Estragon
Registered Users Posts: 4,503 ✭✭✭✭✭
I'm thinking of putting multiple pwm charge controllers on a 350ah 48v bank for winter float charging, eg 2x24v MN brat controllers with either a couple of 12v panels in series, or maybe just a big panel. Can anyone see any problem with this?
Off-grid.
Not enough voltage, you would need at least 4 - 12 volt nominal panels in series to reach 48 volts, with larger panels, you would need 2 - 34+ vmp panels or 3 - 22-32 volt panels, check to see if the controller can handle the extra voltage.Estragon said:..., eg 2x24v MN brat controllers with either a couple of 12v panels in series, or maybe just a big panel. Can anyone see any problem with this?
I was thinking of maybe 2x12v panels in series for~35v into 2x24v pwm controllers, each taking 1/2 of the 48v bank. There would be little, if any, load on the bank - mainly to keep a float on.Off-grid.
You will need to check how the negative wires are connected internally in the PWM.
If you have only two wires coming from your solar array, then you will have a common negative on both PWM's.
Now, the first PWM will connect e.g solar common (-) terminal to (-) lower 24VDC battery. (+) solar to (+) of 24VDC battery
then the second PWM will connect e.g solar common (-) terminal to 'upper (-) 24VDC battery (which gets you 48). (+) solar to (+) of 24VDC battery.
In my mind, this basically shorts out the lower 24VDC battery and makes smoke.-(-)-------24vdc---(+)—(-)-------24vdc-------(+)------
Camden County, NJ, USA
19 SW285 panels
SE5000 inverter
grid tied -
Why not use a Morningstar TS60,45 or 30, they can charge 48v at about the same price or less, as 2 MN Brat's, seems a simpler solution.I'm thinking of putting multiple pwm charge controllers on a 350ah 48v bank for winter float charging, eg 2x24v MN brat controllers with either a couple of 12v panels in series, or maybe just a big panel. Can anyone see any problem with this?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Off-grid.
@mcgivor
The thought was to avoid shipping a couple of big panels or more small panels. It won't take a lot of current to float so the extra is a bit of a waste. I might go that route though.Off-grid.
