Cotek ??? Never again...
Why can they not do a transfer with Cotek Australia?5kVA Victron Multiplus II, 5.2kW array, 14kWh DIYLifepo4 bank, all grid-tied.
Well, you ask me too much !
Why Taiwan didn't care when i told them, after they refused to repair my inverter for free, that i will put many bad reviews about their service on the internet, and why Americas feel so bad they'll give me another one ?
I guess even if they share the name and products, it's completely differents companies...
Good idea for the replacement board, i'll check with them. -
Ok the inverter was sent today. As i said, it's 12v, not 48v, and 1000w not 1500w. Factory refurbished... At least it has a 230v output ! Thanks folks for letting me know the boost transformer wasn't a good idea...
Well, i had to pay for shipping but i hope it will be worth...
It will be used in a new smaller 12v system i'm planning.
So, am i happy ?
Sure, who wouldn't be to have a free inverter ?
I just re read all this thread, and i still mean all that i said.
I of course thanks Cotek Americas, their offer is very kind, and much appreciated after all this story.
Of course i would have preferred not to have to go all this troubles to get there.
This was the first time i claimed something for warranty.
Apparently this is one part that is dealed differently according to companies.
Let's say i was not lucky that time : i picked the bad apple (0,5% failures...) and the guy who took the decision not to repair my inverter didn't had his coffee that day...
I will be able to see if next Cotek inverter will last more than a year, which i hope.
And if it last more than 2, i might even consider buy Cotek again...
At least i will know i have to send it back tu Cotek Amzrixas if i have a problem, not in Taiwan ! -
Do you still have a contact email for the Cotek Americas?
For your information.....Cotek inverters are switch selectable 50/60 hz. Can't change the voltage though. I have 6 years on my Cotek SK-1500-124 a 24 volt 1500 watt unit with no problems whatsoever. I have installed several newer models , the SD-1500-124-HW and SD-1500-148-HW and have had no problems what so ever. I do have to shut if off when equalizing my large format FLA banks as the voltage will exceed Cotek's recommended maximum voltage.
I applaud Cotek for reading the forum and responding to the issue. What Chinese company will do that? Cotek is the only offshore inverter that I will use.2 Classic 150, 2 Kid, 5 arrays 7.5 kw total 2ea. 2S6P Sharp NE-170/NE-165, 1ea. 12P Sanyo HIT 200, 2ea. 4/6P Sanyo HIT 200, MagnaSine MS4024AE, Exeltech XP-1100, 2 Banks L-16 battery, Rolls-Surette S-530 and Interstate Traction, Shunts with whizbangJr and Bogart Tri-Metric, iCharger i208B dc-dc buck/boost converter with BMS for small form lithium 8S 16650 or LiFePO4, -
Hi bitterwolf,
Not sure they would like me to share it on the forum on not...
Here's the one listed on their website, I think they should be able to answer.
info@cotek.ca
Just to add to this old story, the 12v 1000w model they sent me was used on a small back up system for 2 years. As such it was more often off than on, but proved very good when on ( could run a fridge, a freezer and a washing machine together without any surge problem...).
Few weeks ago, it failed... There's a fault code that is apparently meaning "AC fault" and so no output...
Didn't had the time to investigate more yet.
Mat -
You could also try to contact COTEK Support, who offered to help here at post #15
My Cotek SW 2000 suffered a surge from a nearby lightning strike, same AC fault with no output, was an excellent inverter while it worked.mathias said:Hi bitterwolf,
info@cotek.ca
Mat1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
