DIY Solar System Manual Opinions needed.
n3qik
Solar Expert Posts: 741 ✭✭
I have a DYI system, so was bored today and thought it would be a good ideal to create a manual for my system. Look it over, I am stuck on maintenance, what else is there????
Link to it:warning its 13 megs.
http://home.comcast.net/~n3qik/Solar/solar_manual.doc
Re: DIY Solar System Manual Opinions needed.
Hi Ken, minor typo....Square D QO boxes and CBs. I see you have OQ...:roll:
A great start for a generic manual, also a good primer for someone wanting to view an existing install.
Must be realllllly wet down there.
I see a small place in Newfoundland already got over 2 inches up till this morning... and the storm center hasn't got there yet!
What kind of solar input do you normally get during these storms/rains?
Eric
Yikes,
you could optimize the graphics a bit. I'll read it again tomorrow. Nobody understands your system better than yourself. About the best I can think of, is we (reviewers) might catch "Powers of 10" errors, or typos.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks for the input. Will correct the OQ QO thingy. My goal is so that a novice user would have half a chance of keeping it going. If it came to that, hopefully not for some time!!!!
Saturdays output was 30 AH @ 12VDC. -
This is an excellent manual. If I was buying a cabin with such a setup, this manual would increase the value of the system tremendously. Without it, who knows what some yahoo might have set up? Not that I'm calling you a yahoo.
In the table where you show Performance, it might be clearer to say "watt-hours" instead of wattage.
If these are instructions intended for a caretaker, it would be good to have pictures of the actual things in place, to show where they are.
Just like a programmer commenting their own code, this can be good documentation for yourself in the future. When you get to be my age, you could start forgetting things from just a few years back. What gauge wire did I use again? Was that USE-2, or THWN? -
Thanks, Yes lots of room for improvement. Heck it is only draft 1.
Ken the solar yahoo
Version/Draft 2. Thanks for all of the input so far.
New one is only 2 megs.
- 232 Forum & Website
