Generator vs. elements?
stmar
stmar Solar Expert Posts: 373 ✭✭✭
I am going to have my generator on the North side of the house and of course the prevailing wind is from the North. What do you guys use for protection from the elements for your generators? I have been thinking of a portable/temporary tent like structure or maybe a lean-to.
    Re: Generator vs. elements?
    I use a shed. Permanent, keeps all types of weather off, and provides room to store stuff.
    Go for the lean-to over the tent; better protection and less likely to be damaged.
    Are you going to have problems with genset fumes getting into your home?
    Build a simple frame out of 2x4 and use a corrugated translucent panel for the roof ? Allow enough overhang so rain does not blow in, and enough air circulation so it does not overheat. And keep the metal off the ground, some 2x4 sleepers under it ?
  • stmar
    Fumes should not be a problem, it will be far enough away and the wind should keep things cleared out and no windows or doors on that part of the house. I am going through an existing junctions box and using conductors that are already in place from box into house and they are sealed.
    BB. wrote: »
  • Blackcherry04
    I had couple aluminum boxes made for mine, they are 17"w , 26" long , 20" high, open on the end. I guess you'd call them a dog house style. You have to have at least 2 " on each side of the generator the air intake in in the front. The exhaust combines with the cooling air and exits out the back. You don't ever want the generator to get wet.
    I have a picture, but can't get to load.
  • Ralph Day
    Ralph Day Solar Expert Posts: 1,038 ✭✭✭✭
    Don't forget 1/4 inch mesh to keep mice out. I've had them in air cleaners, alternator housings, almost everywhere you wouldn't expect them to get in.
    ralph
  • stmar
    I got lucky, my neighbor had a modular fiberglass box that is just right for my needs, big enough for circulation but not enormous. I will leave one side open, away from the wind and it should shelter the generator when it is needed. It is nice having good neighbors that "keep things" because they might be needed someday. It is a nice looking box and will actually look good sitting by the house.
    Fiberglass shower enclosure ?
  • stmar
    No, actually it is used for industrial electrical work, large junction box. Heavy duty, watertight, bolt together panels that interlock. About 3' X 3' X 2' high, perfect for the Honda EU2000, there were some extra pieces that I can put together for the base/floor to keep it off the ground.
    mike95490 wrote: »
