AC coupling with Sunny Island or XW6048
Re: AC coupling with Sunny Island or XW6048RK_Solar_Hopeful wrote: »... If the voltage drop across the diode doesn't affect operation of the attached Islanding inverter.
May have to find a used inverter (cheap!!) for testing.
The inverter won't care much about a 2v drop (if it's a 48V inverter) Any switching glitches may trip it off-line. And you can't really put diodes in parallel, they don't share current well, unless you use ballast resistors (more voltage drop & heat)
Maybe there are some hhigh power/voltage FET's that you can bias as diodes?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: AC coupling with Sunny Island or XW6048... Maybe there are some high power/voltage FET's that you can bias as diodes?
Thank you for the pointer. Some quick research shows this is a better idea.
