Estimate the size of this panel
Roderick
Solar Expert Posts: 253 ✭✭
This looked like a reasonable design for the price, except that the picture does not look like a 200-watt panel as stated. Opinions, anyone?
http://www.greenbaba.com/Solar-Power-System/PS004-Solar-Power-System-200W.html
Re: Estimate the size of this panel
Thats a 40 watt BP panel. The 200 watt number is probably per day ....
http://www.affordable-solar.com/store/solar-panels/BP-Solar-440J-40W-Solar-Panel -
now that is an example of one that gives solar a bad name. swindlers. for all we know the battery is a cheap fla that came sealed in a box so they think they came get away with calling it a sealed battery too.:grr next thing you know they'll be selling solar tanners.:roll: -
For those who don't do the metric thing, the dimensions given (53 x 26 cm) work out to about 20 x 10 inches. No way on Earth that is a 200 Watt panel. -
i noticed that too marc, but i didn't see the need to mention it as a 40w pv is going to be small like that. it does reinforce that it is not what it is advertised to be though. -
0.53m X 0.26m = 0.1378m^2.Cariboocoot wrote: »For those who don't do the metric thing, the dimensions given (53 x 26 cm) work out to about 20 x 10 inches. No way on Earth that is a 200 Watt panel.
200W/0.1378m^2 = 1451.4 W/m^2.
145% efficiency.
Where can I buy one? What am I saying? Gimme a container ship full of them! ;^) -
Re: Estimate the size of this panelThis looked like a reasonable design for the price, except that the picture does not look like a 200-watt panel as stated. Opinions, anyone?
Buy everything separate, cheaper.... -
here's a pattern:
Mikes Monolith called the Solar Monolith:
Update pictures/information here.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Estimate the size of this panel0.53m X 0.26m = 0.1378m^2.
145% efficiency.
145% efficiency! I only need a few. I can use them to drive a light to shine on the panel, and never need the sun again. I can use the excess energy to make more panels, and the world's energy problems will be solved forever.
