Monitoring systems
rabbit_39
Solar Expert Posts: 43 ✭
Hello,
I'm trying to familiarize myself with the different monitoring systems out there. I am requested to find one that can send sms of the system's status every 30 minutes.
My assumption is that as long as that system can output data to a cellular modem, I'm good to go. But I can't seem to find a monitoring system that has USB or RS232 output that can also be programmed to send a status message every 30 minutes (programmable?).
Anyone know of such a beast?
Thank you,
Thank you,
Re: Monitoring systems
Solar Guppy, has a freeware program SGView that interfaces to the Xantrex GT series inverters, via RS232
http://www.sbcmd.com/solar/ example page 1
http://www.mike-burgess.org/ example page 2
http://www.yourturn.ca/solar/our-system/current-status/ ex page 3
program home:
http://www.solar-guppy.com/forum/sg-view-for-xantrex-gt-inverters-f17.html
This may give you some ideasPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
The SMA sunny webbox allows uploading of data to their web portal over GSM modem.
http://www.sma.de/en/products/monitoring-systems/sunny-webbox.html
EDIT:
Or if you're handy with code, you could build your own using the free yasdi library: http://www.sma.de/en/products/software/yasdi.html
There are quite a few existing projects using this online, e.g.: http://users.coditel.net/vdeconinck/smysqlogger/index_en.xhtml
http://bartfranco.wordpress.com/2010/04/27/sunnyshine-solar-plant-project/
