Looking for logging thermometer
bmet
bmet Solar Expert Posts: 630 ✭✭
Is there an inexpensive thermometer which can log highest and lowest temps over a perior of several days? I'd to know how warm my remote shed gets now that it's fully insulated, circulates air, and has a cooler south face.
Thank you
    Re: Looking for logging thermometer
    You can find USB devices... Probably starting around $20-$50 or so:
    http://www.usbfever.com/index_eproduct_view.php?products_id=257
  • Vic
    And a more basic one can be found at Radio Shack. It i s powered by a single AAA battery, has indoor, and outdoor temps -- outdoor uses a sensor at the end of about 10-12 feet of small diameter cable.. The display shows indoor and outdoor temp, and is settable for either degrees F or C. It has an indoor humidity display, which may or may not be accurate, it is limited to a minimum display of 20% indoor RH. A pushbutton allows the dispaly of high and low indoor/outdoor temps.
    Use two of them here, and they have been fine. Use the putdoor probe to display the battery temp, asi it is attached to a battery with all the other BTSes.
    At $20. retail seemed a bit expensive, But have had these two for about five years, and they will run for 3-4 months on a single rechargeable NIMH battery, and no probs with either of them.
    Vic
  • bmet
    Thank you BB and Vic. The USB data logger is almost what I am looking for. Got to seek out one that would work for Mac or Linux OS.
  • RCinFLA
    http://www.amazon.com/Extech-TH10-TEMPERATURE-USB-Datalogger/dp/B001CN5JKA/ref=pd_sim_hi_1
    Extech also make a temp logger for $55 and temp + humidity for $85
  • bmet
    Thanks, still hoping to find one compatible with 'other' OS.
