Q: Why would you want to allow your wind turbine to free spin?
foolios
Solar Expert Posts: 53 ✭✭
Looking up brake info, I see options on the brakes.
Why would free spin be an option? I read free spin happens when loads are missing and the battery is overvoltage; which could result in the destruction of the turbine.
Switch Positions:
- Up -- Turbine is connected to the battery or rectifier. (Switch is closed)
- Middle -- Turbine is fully disconnected, free spinning.
- Down -- Turbine wires are shorted together. Brake is on.
Maybe so you can work on it with circuits open, check to make sure it spins with no load, etc?Off-grid.
Kind of what I was thinking, a neutral gear of sorts, to test the bearings without load or brake.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Excellent.
Thanks. -
A lot of double pole double throw switches have a middle position where they are off...
BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
- 621 Discussion Forums/Café
