Will a 12v DC water pump work if directly connected to solar panels without a battery?
noradawn456
noradawn456 Registered Users Posts: 5 ✭✭
Most of common DC water pumps can work directly connected to the solar panel, but their biggest problem is stuck. At dawn, the sunlight begins to change from weak to strong, when the output voltage of solar panel achieves the starting voltage, the pump will start to work. But at this time the solar panel can’t provide its full performance, the voltage will decrease significantly because of the load. If it drops to a voltage which can’t maintain the pump running, the pump will get stuck.
    The function of a Linear Current Booster (LCB) is to work around panels not well matched to the motor.   It will cause the motor to run in short useful bursts, instead of slowly turning and not doing any work.   Our host sells them
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,046 ✭✭✭✭✭
    I cant find any LCB on the host site. Lots of pumps and shunts. Do you have a link?
    There might be a difference between brushed and brushless motors. I've had no problems running, or I should say a friend hasn't... I bought a cheap brushless water pump with a 12-24 volt range and it ran off a single 55 watt solar panel, in a hydroponics system. I think it was on a timer, so might not have had the situation you are inquiring about, but circulated nutrient rich water in her system.
    Darn them. Who want's used LCB's ?  now you have to go off-site.
    NAWS !  why does your store search engine return 20+ hits for Linear Current Booster and shows Shunts and current sensors ?
    Google is your friend
    I have sent an email to NAWS about the wrong search results... I think the following is probably what NAWS stocks/sells at this time:
    https://www.solar-electric.com/residential/solar-water-pumping.html?cat=772
  • littleharbor2
    Trying to figure out what makes an LCB so expensive.  Amazon has a 48 volt, 10 amp version for $435.00  plus $69.99 shipping for a two pound item.
    They are, more or less, very similar to MPPT charge controllers (switching power supply).
    Probably not as much volume/quantities as solar charge controllers.
    I agree, they seem to be very expensive.
  • Equinox
    Equinox Registered Users Posts: 6 ✭✭
    Most DC pumps will have problems to start as there operation point does not match the operation point of a pv panel.
    If the pump does not rotate it will basically actas a resitor and almost have the panel operating in short circuit.
    A very reliable DC-DC controllers for mid size systems (150 Watt) which is especially developed for deep well pumps is the Shurflo LCB-G75
    sold e.g. by Phaesun:
    http://order.phaesun.com/index.php/accessories-40894/pumpaccessories-40922/shurflo902200pumpcontrollerslcbg-41039/pump-controller-shurflo-lcb-g75.html?___store=default&___from_store=german
    A very reliable pump for small system is the ecocirc D5 vario. This is a pump that can directly be connected to solar panel as it includes a built it MPP controller. Its operating voltage is from 8 to 24V DC..
  • jonr
    I've used a simple brushed DC pump directly connected to panels.  Worked fine without a LCB.
    Rick are NAWS has fixed the lcb search results.
    More or less, pump torque is proportional to motor current. Solar panels are more or less current sources (50% sun=50% torque).
    The LCB takes solar panel power at low current and fixed Vmp (=Vmp*I sun) and converts to high current & low voltage used to start the pump motor). Solar panels, when there is, at least, weak direct sun, run a constant Vmp and low Isun current.
    If the pump does not start against high pressure, then it does not take much starting torque to get running).
    Bill
