Adjustable tilt roof mount spacing
There are really cool apps for solar tilt. loaded with info and turns your phone into a tilt gauge. It uses GPS to give you exact tilt for any day of the year and you can input any coordinates and get tilt specs for anywhere on earth.
My App is simply called Solar Tilt.
I just tried it, and it worked for me (default browser on Samsung note3 via wifi in Fl panhandle).Off-grid.
littleharbor2 said:There are really cool apps for solar tilt. loaded with info and turns your phone into a tilt gauge. It uses GPS to give you exact tilt for any day of the year and you can input any coordinates and get tilt specs for anywhere on earth.
My App is simply called Solar Tilt.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Bummer. There's got to be a way around this. Wish I was more tech savvy. I've had mine for years and I'm sure I didn't need to back up anything. Hope you work it out. It's a really cool and useful app. If nothing more for the highly accurate angle finder. You set your phone on edge on the surface of your panel(s) and you instantly know your tilt.
littleharbor2 said:Bummer. There's got to be a way around this. Wish I was more tech savvy. I've had mine for years and I'm sure I didn't need to back up anything. Hope you work it out. It's a really cool and useful app. If nothing more for the highly accurate angle finder. You set your phone on edge on the surface of your panel(s) and you instantly know your tilt.
The constant stream of Google and Microsoft updates are irritating. Especially when one finds they frequently download more data than they update. Coupled with their reputation.
I have the Solar Tilt app now....thanks for that.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Here as well.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
BB. said:
Bill, Have you seen , or used the app Solar Tilt?2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
Another way to get tilt angle of any surface is to download an app called iHandy Level
Not solar related but works great to find a tilt angle for any surface.
23.16kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro System monitoring -
DanS26 said:Another way to get tilt angle of any surface is to download an app called iHandy Level
Not solar related but works great to find a tilt angle for any surface.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
I have not used the solar tilt software (or much of any solar gear. I was not in the business).
BB. said:I have not used the solar tilt software (or much of any solar gear. I was not in the business).
Bill
It's just a simple, free app for your phone. Fun to play with also.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
- 628 Discussion Forums/Café
