Sigineer (Chinese, Transformer Based) Power Inverters
Has anyone looked at the chinese power inverters offered by www.sigineer.com ?
I have one installed in my setup, and for the $1650 delivered, I dont think it can easily be beat.
12KW continuous, 36KW for 20 seconds...
And check out the inside:
https://www.youtube.com/edit?o=U&video_id=Hc6KyXbWTcU
0
At 90% all three gens are pretty much maxed out.
Soon I will be buying an 18KW Perkins....Just gotta save up a while longer for it.
180 watts self consumption is 4.3 kWhs per day just having it online.
To be honest, I never calculated idle draw of the inverter in terms of how many KWH/day....At design, 180 watts seemed miniscule to the other loads. Thank you for pointing this out. I will be going some time this week to check and see if that 180 watts is accurate. If it is, then that is half of my daily consumption........
Interesting.
I dunno though, the whole setup looked pretty scary to me. Small cables, open cable connections, for potentially very large loads ... Call me crazy, but I'm not installing that set up in my house.
MN Solar Classic 150 / Conext SW 4024 Inverter latest firmware
Trojan L16H-AC 435Ah bank 4S connected to Inverter with 10' of 4/0 cable / 24 volt system
Grid-Assist Off-Grid / Need 3200Whs Daily
System, Pics and Discussion
Edit. An excerpt from an article discussing battery short circuit
