Hand Shake Agreements
southforksouthfork Registered Users Posts: 20 ✭✭
When I was having my solar installed I asked if the run back to the main panel was heavy enough to  attach a gen set to so I could keep the noise away from the house . The contractor answer was sure I would likely need a dedicated circuit and a plug ? and would need to turn breakers off to solar array and at the main ? To avoid damage to equipment and back feed but since we already pulled permit he would do the work after inspection  My agreement was cash when the array was producing I upheld my end . But after numerous unanswered e-mails and cell phone calls to find out about said plug ? His answer was his agreement with me was to install the solar system as per written agreement . So the handshake and verbal agreement didn't amount to anything live and learn If i held up payment until all implied work was complete I bet I would have my Plug ? This was a local solar contractor with good reviews . So now I need to hire a real electrician to install a gen set disconnect .
 24 solar world 285 watt panels with 24 Enphase 250 s ground mount grid tied .
  • PhotowhitPhotowhit Solar Expert Posts: 4,306 ✭✭✭✭
    Yep...sorry.
    Hand Shake Agreements are only as good as he hands you are shaking. Let others know. Google reviews, BBB, etc.
    Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites,  Midnite E-panel, Prosine 1800 and Exeltech 1100, ForkLift battery. Off grid for @13 of last 14 years. 1000 watts being added to current CC, @2700 watts to be added with an additional CC.
  • EstragonEstragon Registered Users Posts: 1,723 ✭✭✭✭
    Turn off breakers to run the genny? Wire it after inspection? Gah. I hope your local inspectors are good and really inspected what this guy has done.
  • softdownsoftdown Solar Expert Posts: 1,610 ✭✭✭✭
    Our class president became a cop. He knows people. His advice: Trust noyone.
    First Bank:16 180 watt Grape Solar with  FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 150 watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
  • wellbuiltwellbuilt Solar Expert Posts: 188 ✭✭
    Ya never pay till the job is done and inspected. Never never
    but I'm sure for every contractor that did not finish a job there are 3 dirt bag people that'dident want to pay .
     It is what it is , the truth is the contract is only as good as both party's . It is hardly ever worth going to court in the end .
     This is the contractors side of the story.
  • southforksouthfork Registered Users Posts: 20 ✭✭
    Everything was inspected and up an running before payment was made the system is working as designed or better no problem with quality of workmanship the crew did a great job . My problem was with the company owner and a handshake . The system has been net-0 since install with surplus power and the 30 percent credit back in the bank . I guess I'm old school but a man's word is everything .
