Skeptical of this 1000watt Inverter Board
SolarPowered
Solar Expert Posts: 626 ✭✭✭
So there is this company on ebay that claims they are selling a 1000watt inverter board. The price looks dirt cheap and looking at the circuits required for it, to me it seems like a 500watt board for a 1000watt peak surge.
Anyone deal with this type of board to know what I am really looking at here? Seems like shady sales to me.
Re: Skeptical of this 1000watt Inverter Board
This is just a board without any parts soldered on it. -
Re: Skeptical of this 1000watt Inverter BoardThis is just a board without any parts soldered on it.
I know its just "the Board" as the title of the thread says.
This is what it looks like with all the assembly parts for $128 shipped. Seems a little to inexpensive, the torroid doesn't look big enough and the Uf capacitors, don't meet the criteria.
Attachment not found. -
Re: Skeptical of this 1000watt Inverter BoardSolarPowered wrote: »This is what it looks like with all the assembly parts for $128 shipped. Seems a little to inexpensive, the torroid doesn't look big enough and the Uf capacitors, don't meet the criteria.
I wouldn't buy a board and use kit parts to replicate a Chinese inverter. If you want to do that, order an assembled board.
You can buy a kit and then replace parts that you don't like before soldering. Or you can buy all your own parts which meet your longevity/power requirements. -
that "kit" is going to need heat sinks, and some sort of thermal feedback control. IS it sine wave or mod sine ? Then you need a case & a fan and ..............Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Skeptical of this 1000watt Inverter Boardthat "kit" is going to need heat sinks, and some sort of thermal feedback control. IS it sine wave or mod sine ? Then you need a case & a fan and ..............
Its sold as a sine wave. The test results show that it is of a 60hz sinewave. I highly doubt however with one torroid of that size and the capacitors that it is barely making 500watts continuos, it almost appears to be a 350watt pure sin wave sold as a 1000watt according to the circuit layout.
Here is a pic of what a true inverter 1000watt should look like, and this is just from a Modified wave inverter, which can accept the processor (micro controller chipset) to convert the wave to pure sine wave.
You can get the board only for $8.99 from ebay HERE. It would be a fun learning exercise to put one together.You could probably scrounge most of the parts from junk electronics or buy the parts new for less than $50. Hmm ... Maybe I'll add it to my list of electronics learning projects.
But I don't think I'd want to use it for any critical inverting task.....:roll: -
Re: Skeptical of this 1000watt Inverter BoardYou can get the board only for $8.99 from ebay HERE. It would be a fun learning exercise to put one together.You could probably scrounge most of the parts from junk electronics or buy the parts new for less than $50. Hmm ... Maybe I'll add it to my list of electronics learning projects.
The board layout is better suited for Micro Inverter function. If you analyze the board, and processor it has all the basic components needed for a micro inverter. I believe to label it 1000watts seems a little over rated. This board seems to be stackable for parallel applications, so maybe it could function up to 1000watt, but the board appears to be a 350watt board from most of the boards I look at . I've already put together pricing on most of these parts for larger torrid (torrid alone is $35), Mosfets ($5 each),capacitors ($3.75 each) from frys electronics, however the vendor says you have to buy the board before he/she is willing to divulge the information for the processor (processor is around $45) which is the most important function of the pure sine wave. Without the processor its just junk. -
Re: Skeptical of this 1000watt Inverter BoardSolarPowered wrote: »I've already put together pricing on most of these parts for larger torrid (torrid alone is $35), Mosfets ($5 each),capacitors ($3.75 each) from frys electronics, however the vendor says you have to buy the board before he/she is willing to divulge the information for the processor (processor is around $45) which is the most important function of the pure sine wave. Without the processor its just junk.
Much cheaper to get parts through Digikey, mouser, Arrow or even ebay. Sub $1 for caps (maybe a bit more for the 2 large filter caps), $2-3 for mosfets. Toroids more but not $35 (likely less than $10). $45 for the MCU? Highly unlikely. Sub $5 likely - Do you know what it calls for? This doesn't exactly need highly sophisticated processing. Likey 8 bit AVR or similar. No more than $10 I would guess.
OK Edit - now that I look closer it looks like it is using a " pure sine wave inverter on a chip". It's hard to see but it looks like it is using a daughter board with an EG8010. It does look like it puts out a true sine wave.
You can buy the daugther board with chip installed for $15.99 on ebay HERE. In fact as you can see that listing links back to the same inverter board for sale. (oh - found it for $8.98 on ebay HERE )
Or for $8.36 on AliExpress HERE. AliExpress also has the individual chips for $1.96 in lots of 5. -
Input voltage (P3+ P4-) DC24V. JP2 bridge but U1 7812 Voltage regulator burnout. But it is working with DC12V JP3 bridge and without U1 7812. Any solutions ?
The EGP1000W is missing a lot, even populated. As per the schematic, there are no FET drivers, NO transformer, NO controller, no heat-sink, no current or voltage feedback circuitry, no overload protection, no a LOT of things. i.e. all it is is a full bridge stage without a brain. Maybe if you want to tinker ?
Cheaper to buy a small-ish Chinese inverter. They usually even work.
One caution, some of the components are surface mount and I can't figure out why. There is plenty of board space for thru hole. Surface mount adds another layer of difficulty.
- 218 Forum & Website
- 647 Solar Water Pumping
- 813 Wind Power Generation
- 599 Discussion Forums/Café
- 73 Construction
