SW 5548 Mosfet Replacement
eteke
Registered Users Posts: 3
Hi All,
Anyone help me with replacement mosfet and mosfet thermistor combo values. these are from a sw 5548 unit. couldn't find anything.
Attachment not found. Attachment not found.
Re: SW 5548 Mosfet Replacement
I found RFP40N10 at DigiKey, although they don't have it in stock. You can get the data sheet and then buy something else with similar specs. -
Re: SW 5548 Mosfet ReplacementI found RFP40N10 at DigiKey, although they don't have it in stock. You can get the data sheet and then buy something else with similar specs.
Thanks, I found the same. I am going to go that way but most difficult one for me is the thermistor. any ideas what are the values or what can I use as replacement. -
Re: SW 5548 Mosfet ReplacementThanks, I found the same. I am going to go that way but most difficult one for me is the thermistor. any ideas what are the values or what can I use as replacement.
Xantrex (Shneider Electric) may be able to tell you. They may even have a replacement. -
Re: SW 5548 Mosfet ReplacementXantrex (Shneider Electric) may be able to tell you. They may even have a replacement.
Don't get your hopes up. They are not too keen in the customer service department. It's hard enough to get an answer about a new piece of equipment. You will probably find their position on the venerable SW series is "no longer supported". That's if you get an answer at all. -
I'm also after the thermistor value, the one on the MOSFET i've removed reads 92k @ 25c - I'll let you know if I manage to work it out. -
I think it may be one of these http://http://uk.farnell.com/avx/nb20n00823jba/thermistor-ntc-82k-1206/dp/1672324
My measurements
~82k @ 25c
8k @ 85c
4.7k @ 100c
Apart from a relay board schematic, has anybody any other schematics for the SW series ?
Regards
Simon. -
For the MOSFET's, FDP090N10 works well.
Make sure you minimally change all the H-bridge set driving a particular transformer. The MOSFET's driving 'Papa Bear' transformer have the most parallel MOSFET's and most likely ones to blow. I don't remember the number of parallel MOSFET's but the large transformer has the most in parallel. Just follow the leads off the top of the big transformer.
Sun Electric in Miami might have a complete MOSFET board available. -
I'm going to try PSMN6R5-80PS on the SW3024E (don't use on the SW5548), I'm replacing all the MOSFETs and drivers. Have checked all the drive resistors (some smoked) and the diodes.
The fault was caused by an insulation breakdown on the output common mode choke L1, causing a short and smoking most of the MOSFETS on the MAMA bear stage, one of the driver chips then went short and the unit wouldn't boot with the MOSFET board installed, had to inject the power supply direct to the CPU board to test as the MOSFET board supplies this voltage from the connected battery. See http://www.navitron.org.uk/forum/index.php?topic=17577.0
Simon. -
I used 2 pairs of pliers to retrieve the original thermistor, use one pair to hold the mosfet body and the other pair to bend back the metal tab, in my case the thermistor and epoxy just came away from the mosfet tab and body, measured the resistance just to checked it had survived !
The thermisitor is a surface mount diode type.
Hope this helps. -
Thanks for all the input. Great info...
I have 2 of these 5548s and I just swapped the good boards,-I thought they were good- and made a single unit. until I get the right mosfets etc. now when I turn on this new unit; it trips the PV Ground fault breaker, starts humming, no fans running, everything else looks fine and inverts. anybody has any ideas. what might be the problem. -
Re: SW 5548 Mosfet ReplacementThanks for all the input. Great info...
Sounds like unrelated ground loop connection problem. My guess is because of your negative/grounding wiring the SW5548 is jacking your PV ground up slightly in voltage potential causing PV's ground fault to trip. -
I’m having a problem with my trace sw5548 and looking for anyone with experience repairing them, if anyone would be willing to help my email is morejiggawatts@gmail.com would much appriceate it.
its making 170vac 54hz has artifacts in the sine wave and sounds garbled instead of usual hum its supposed to make. -
Here is a list of folks that have been known to repair AC inverters... The list has been around for awhile, some folks may no longer be in business:
https://forum.solar-electric.com/discussion/comment/241766#Comment_241766
Not a recommendation list, I have no knowledge of these folks other than what has been posted.
the guys at inverter service center https://inverterservicecenter.com/ in whitehouse TN have a lot of spare parts....you can call and find out
jiggawatt said:I’m having a problem with my trace sw5548 and looking for anyone with experience repairing them, if anyone would be willing to help my email is morejiggawatts@gmail.com would much appriceate it.
can you measure the voltage after it comes out of the coil
- 218 Forum & Website
- 185 Solar Information links & sources, event announcements
- 647 Solar Water Pumping
- 813 Wind Power Generation
- 599 Discussion Forums/Café
- 73 Construction
