AC coupling with Sunny Island or XW6048
2»
    Re: AC coupling with Sunny Island or XW6048
    ... If the voltage drop across the diode doesn't affect operation of the attached Islanding inverter.
    May have to find a used inverter (cheap!!) for testing.
    The inverter won't care much about a 2v drop (if it's a 48V inverter) Any switching glitches may trip it off-line. And you can't really put diodes in parallel, they don't share current well, unless you use ballast resistors (more voltage drop & heat)
    Maybe there are some hhigh power/voltage FET's that you can bias as diodes?
  • RK_Solar_Hopeful
    RK_Solar_Hopeful Solar Expert Posts: 69 ✭✭✭✭
    mike90045 wrote: »
    ... Maybe there are some high power/voltage FET's that you can bias as diodes?
    Thank you for the pointer. Some quick research shows this is a better idea.
