Mounting question
gpt
Registered Users Posts: 18 ✭
I have a roof that is 9x25 ft. If I fit 2 rows of panels 62 inches long, there will be a little bit of an overhang. Is it an acceptable practice to mount them so they are about a foot above the peak? Thanks in advance
Re: Mounting question
If a good gust of wind comes from that direction, you may see some breakage. Otherwise, they seem like they would sit there just fine.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
If this is a "building permitted" installation--you probably would need the signoff of a PE (Professional Engineer) anyway--And this should be exactly what he will be signing off for (based on the rating of the panels, racking system, and your peak winds in your area).
Given that people mount arrays on exposed mounts (ground, tower, 1 and 2 axis trackers, etc.)--I don't see an issue unless the mounts are two far from the cantilevered ends (basically, the standard is to mount the rails 1/4 in from each edge. If not mounted this way, then the loads are not evenly distributed across the panel frame and mounting hardware.
Unirac has some good information (even for the PE) on their rack mounting hardware... Looking through there may give you some ideas.
