Equalization
I have a Magnum 1000 sinewave and eight 6 volt Trojan batteries. How do I equalize if I don't have a switch on the inverter
  • mike95490mike95490 Posts: 7,705Solar Expert ✭✭✭✭
    Your charge controller should have the EQ function, not the inverter.  Use the inverters internal charger (if it has one) to bulk the batteries in the morning, and let solar take over for Absorb and then EQ ?
    Does your inveter have a charger in it ?   Or use your generator and charger to bulk the batteries in the AM
  • MrM1MrM1 Posts: 157Registered Users ✭✭
    Do you have or have the option to have a Magnum Remote Control Panel.  I would guess you need one to fine tune the inverter settings.
    REC TwinPeak 2 285W 3S/3P 2.6kW-STC / 1.9kW-NMOT Array
    MN Solar Classic 150 / 2017 Conext SW 4024 Inverter latest firmware
    Trojan L16H-AC 435Ah bank 4S connected to Inverter with 7' of 4/0 cable / 24 volt system
    Grid-Assist Off-Grid / Need 3200Whs Daily Off-Grid
    System went Online Oct 2017
  • ThomThom Posts: 180Solar Expert ✭✭✭
    Remove the fuse or turn off the circuit breaker. You do have some form melt down protection ?
    thom
    Off grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator
