Quick question
Rthomas911Rthomas911 Posts: 1Registered Users
Can two 110 inverters push a 220 well pump if they are pure sound wave inverters???
  • EstragonEstragon Posts: 2,451Registered Users ✭✭✭✭
    Not unless they're designed to do so. Some are series stackable, but unless designed for it, there will be a phase mismatch between the two legs.
    Off-grid.
  • mike95490mike95490 Posts: 7,709Solar Expert ✭✭✭✭
    Stackable inverters have a "sync" cable, so that the magic smoke is not released
  • oil pan 4oil pan 4 Posts: 685Solar Expert ✭✭✭✭
    The short answer is definitely no.
    Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
    Solar roof top GMC suburban, a normal 3/4 ton suburban with 180 watts of panels on the roof and 10 amp genasun MPPT, 2000w samlex pure sine wave inverter, 12v gast and ARB air compressors.
  • MichaelKMichaelK Posts: 75Registered Users ✭✭
    Look at Schneider's SW4024 inverter.  It has both 120/240 output to begin with, but if extra capacity is needed they can be paralleled to put out up to 14,000 watts of 5.0 second surge
    https://ressupply.com/inverters/schneider-electric-conext-sw4024-120240-invertercharger
    If you have a little pump (≤0.5HP) a single 4024 might start it.  Two 4024s in parallel will surely start it.
    I'm now running my 1.5HP well pump off a Schneider XW6848.
    15 Renogy 300w panels,  Midnight 200 CC, 8 Trojan L16 batteries, Schneider XW6848 NA inverter, AC-Delco 6000w gen.
