Well, I never expected this when I got home!
2twisty
2twisty Solar Expert Posts: 199 ✭✭✭
Wife told me that she heard a loud "POP" sound, but that the power was just fine.
I came home to this:
Looks like something got a little toasty on that negative terminal and ignited the gasses in the battery.
Strangely enough, the bank was still functional!  Well...not really, but it didn't break the circuit and the middle cell was still trying to charge as evidenced by the bubbling.
Thankfully, I had a spare battery from my dead bank of batteries that was still holding a charge well and I was able to swap it in to get the bank back online quickly.
And double thankfully that nobody was out there when it ignited, since I'm sure it sprayed acid everywhere, too.
  • westbranch
    edited December 2017 #2
    water down any evidence of acid before attempting diagnosis and repairs... and please put at least a piece of plywood over the bank for snow/rain protection.
    I think you need to determine what caused the overheating and ignition, maybe the same or maybe not....
    there was a lot of heat in that cable shown in pic #1 and a lot of gas production to vent and explode...
    West Chilcotin, BC, Canada
    BB. Super Moderators, Administrators Posts: 33,448 admin
    I can't tell if the wire insulation was damaged by heat--or just mucked up over time (water, electrolyte, etc.). The copper crimp end looks pretty good--I don't see signs of overheating.
    About the only thing I can think of that would be caused by "you"... Water levels been ok in all cells (low water level can cause cells/exposed plates to behave badly)--Possibly cause excessive gassing/overheating when charging.
    If the case got cracked from handling (battery got moved/dropped/bumped--especially in cold weather and brittle case), could also cause loss of electrolyte...
    Dropping of a tool/something metal across the top of the battery bank? (accessible to kids playing around?).
    Otherwise, the wiring looked clean and the terminals looked fine.
  • mcgivor
    edited December 2017 #4
    That negative terminal looks melted, heat travelled along the cable, the green jumpers appear to have UV damage, batteries should really be covered and not exposed to the elements. Good thing that was the extent of the damage, it could have been a lot worse with wood close by, do you have overcurrent protection, there must have been some serious current to melt the terminal, if in fact thats what happened,  i don't see a fuse.
  • Estragon
    I would make a baking soda solution to neutralize acid for clean up, and wear full protective gear.
    Any chance that battery was really weak, and got charged frozen?
    +1 on making an enclosure.
    Off-grid.
  • jonr
    edited December 2017 #6
    Hot terminals don't ignite hydrogen gas (unless we are talking about much hotter than the melting point of lead and plastic).  But arcing caused by water across terminals can.    Keep your batteries dry!
    Odd, the wire is definitely overheated, but the copper strands visible. aren't oxidized.  Maybe the hot wire melted the terminal and the wire wobbling around in the puddle of lead, started an arc that lit the hydrogen.
    What sort of amps are going through that wire normally ?
    Lucky that's all that happened.
  • westbranch
    Mike, good eyes on that melted post, missed it... saw the charred wire covering.
    Hope you are not in line of the current fires.
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 6,753 ✭✭✭✭✭✭
    A poor crimp? or one that was stressed?  The other end of the terminal / wire bond that you can't see maybe the failure point?
    When I see different makes of cables in a battery system I am wary of this exact kind of event.
    The fires are way south of us and Mike, for a change this year Mr West!
    E-mail offgridsolar@sti.net
