my wind turbine
fantom007grfantom007gr Posts: 20Registered Users ✭✭
  • fantom007grfantom007gr Posts: 20Registered Users ✭✭
    hellow  everybody from athens greece.
  • mvasmvas Posts: 298Registered Users ✭✭✭
    edited May 2017 #3
    Very nice!
    With Wind Turbines the rule is ... The higher, the better.
    Can you raise the turbine higher, to get above the roof's turbulence ?
    Some questions ...
    Diameter of the rotor = ?
    # of Kilowatt-Hours it generates per Year = ?
    # of Kilowatt-Hours it generated on its best Day = ?
    Are you charging a battery bank?
    this is what  changes i did today.some diferent arangement.
    diameter of rotor is 120 cm
    the generator is 1000w ,from usa but it never produced this power.
    140 wh the batery.
    edited May 2017 #9
    It is best if the Wind Turbine is 10 meters higher than the top of the nearest structure.
    I see that you have changed from one tail, to two tails.
    Did you have a problem keeping the blades pointed into the wind?
    Does the wind blow at a constant 6+ m/s, for many hours per day?
  • aminaelisaminaelis Posts: 14Registered Users ✭✭
    Great job! Looks awesome. Are you satisfied with the outcome? I suppose Athens are not the windiest location...  :D
    one of the tries i attemted, here with my old washing machine.
    some new projects,and with the pulley i h
    with the pulley i have mutch better performance
  • BB.BB. Posts: 27,444Super Moderators admin
    How well does it point into the wind? The length of the arm to the "tails" seems pretty short (they are mostly to the "side" of the pivot point, not very much to the "rear" of the pivot/yaw bearing).
    hellow bill,thanks for your notice my friend,well the wind turbine is staying against the wind but also you can see looking around many times left and write ,so it misses a lot of power,yes it does twist alot in high winds,but in the other hand is like furling .thats why i am building  the wawt now ,the vertical wind turbine.
  • mike95490mike95490 Posts: 7,654Solar Expert ✭✭✭✭
    Looks like you are building up an axial flux generator ?
    yes mike,my next plan ,but it takes me a lot of time which i dont have ,and it looks that it will take time.
    i am in the time that i need to test the rpm of the constaction with the wings i have so i will after fix the coils .i will post pictures.
