Scenario - im new to charge controller function
bsolar
Solar Expert Posts: 103 ✭✭✭
12v system stand alone system, its not grid tied - (2) 2500w inverters, (8)210ah golf cart batts wired to 12v, (12) panels that put out roughly 8amps each at peak sun.
...my question is - during peak sun hours i run the system, water pumps, fridge, fans, ect and pull alot on it .. can i expect (2) C60 chargers hooked into the bank and drawing from the same common output of the array to function to keep up with the load? will that work right or is my thinking flawed?
Your thinking is flawed if you intend to share one array with two controllers, each controller should have its own separate array, you could split the current array into two, the controller outputs can be commoned as long as the settings for both controllers are the same. Sidebar, that's a lot of inverter for a 12V system.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
If the C60s are the ones I'm thinking of, they're PWM type. I think if they were MPPT, they would confuse each other as they sweep to find max power point.
I'm guessing your 12v panels are wired in parallel for ~100a. If so, and the CC is PWM type, I don't see why it wouldn't work. It would need pretty heavy wire to handle 100a though.
With that many panels (and batteries) in parallel you should have the parallel connections done with properly sized fuses or breakers.Off-grid.
ive got one yay and one nay .. sounds like the common outputs wont be a problem with the same settings ... i still have a question on whether or not i can draw from my current setup with both controllers - the c60 controllers 'are' pwm all the panels are wired and switched individually to a large pos and neg buss bar in a panel box i made up .. theres really no room in the box to create 4 buss bars i would have to get another box and redo alot of wiring to in essence create two arrays .. but if its necessary i will ultimately do it ...
* on the inverters, plenty over overhead for sure, no bottleneck there lol .. theyre sunpro true sine inverters, i can put one on each leg of my panel box if necessary, backfed through a pump 240 line in the garage, thats the layout ...
Connect each charge controller to it's own set of panels/Array. Connecting them to the same battery bank will be fine.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
I'm with Photowhit, 2 controllers 2 arrays, one battery bank
alright, thankyou guys .. i'm going to get into my array bus box and see if theres a way i can modify it so i dont have to build another box and wire it - cut the bus bars in half, drill them for another lug attachment ect ..
Some are designed to work with 2 circuits, it might help to see one;
If you just want to add a 5-6 string box, there is alternative on eBay right now.
If you are doing fuses;
http://www.ebay.com/itm/Hoffman-Steel-6-String-Solar-Combiner-Box-SCB884M6S-/281950201745?hash=item41a58aa791:g:OAsAAOSwPc9W1P~X
And if you already have breakers, I think the jumper comb would work for them.
Photowhit and Westbranch - why do PWM controllers need their own array? Just trying to understand.Off-grid.
If you could get a manufacturer to sign off on it I would be fine, but 2 operating near capacity, I would wonder about one switching to float, and what the other would do with the added available input. Also these are switching on and off rapidly to limit voltage, so you have the available current fluctuating.
Bill might have a better idea of it's feasibility. I can certainly be wrong!
MPPT controllers need their own array because they "sweep" the current and measure the voltage of the array--To figure out the Vmp and Imp operating points. If there are two or more MPPT controllers on the array, they will confuse each other.
With PWM controllers, you can have one array going to two (or more) MPPT charge controllers (assuming they share the same ground/negative battery bus connections) charging two different battery banks (for example, on an RV, charging both the house battery and vehicle battery).
However--The array must not be larger than the rated capacity of the smallest PWM controller attached to the array. If you have a 20 amp charge controller, the array cannot be larger than 20 amps. PWM controllers do not have the ability to limit the operating current through them. If you had a 40 Amp array and 20 Amp PWM controller--There would be 40 amps flowing through the PWM charge controller and it will attempt to pass all the available array current through the charge controller to the battery bank--Either shutting down (over current or over temperature) or fail.
MPPT charge controllers have the ability to safely/reliably limit their output current via the MPPT circuitry (switching power supplies have current throttling capabilities because that is how the, typically, buck type switching supply works).
Thanks @BB. You took the words of the tip of my tongue, been thinking about this for a while, so in essence one could parallel two PWM controllers to a single array, but the array must be limited to the smallest controllers maximum current capacity, therefore there is no advantage in doing so, other than to reduce the demand on the electronic components of said controllers. So, if for example, the array has the potential to supply 60A, it would be advantageous to split the array into two 30A circuits using two controllers rated at 30A, or use a single 60A controller, no free lunch, but brain food, none the less, thanks again.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
You got it McGivor.
The Schneider C60 apparently has overcurrent protection, so in theory I guess @bsolar could get away with the one array.
That said, rather than rely on the controller to protect itself with ~100+Adc coming at it, seems to makes sense to split the array.
To split my 48v array, IIRC I just had to cut the +bussbar in the combiner and wire a controller to each piece. No extra boxes or bussbars. Would that not work?Off-grid.
Estragon said:The Schneider C60 apparently has overcurrent protection, so in theory I guess @bsolar could get away with the one array.
theres just no room in my box and it was wired 'in place' as it were .. theres 24 stiff 12 gauge wires running into the box , then into 12 switches on the Pos side then on to the bus bars ... disassembling, cutting and trying to rig it would be a nightmare, but the box does have some room - i went ahead and bought 2 more bus bars and it 'should' ( hopefully) have enough play in the wires i can rewire everything without disassembling ... im committed to the operation at this point and bought the second controller .. its do or die heheh .. thanks again for brainstorming with me though ..
I believe the C60 will simply shut down. It will not "throttle" the current on a reliable/useable manner.
- BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
Sounds like its time to upgrade to 24 volt.
littleharbor2 said:Sounds like its time to upgrade to 24 volt.
The C60 will work with up to 85A of array but will shut down above that.
Here is a PWM controller that isn't limited in array amps. I'm not surprised, given that designing current limiting mosfet circuits isn't hard.
"Charger will safely reduce output if panel current exceeds 31 amps."
http://www.bogartengineering.com/products/solar-charger/
- 628 Discussion Forums/Café
