Murky Battery Cell
TombslTombsl Posts: 13Registered Users ✭✭
I have one cell in one battery in my off grid system that appears brownish and murky.  Any thoughts about why this is happening and what I can do about it ?
  • mvasmvas Posts: 298Registered Users ✭✭✭
    edited December 2016 #2
    Lead dioxide is brownish in color.
    PbO2 is what the positive plate is made of.
    Did you over-charge the battery?
  • TombslTombsl Posts: 13Registered Users ✭✭
    The voltage to the battery bank is controlled by a three stage controller, so it shouldn't have been over-charged. by the solar panels. I do have a high capacity charger attached to the batteries but it also has a controlled charge. So I think the answer is no.  Thanks for the feedback. Do any other possibilities come to mind?
  • mike95490mike95490 Posts: 7,557Solar Expert ✭✭✭✭
    How old is the battery?   Eventually, one cell fails.  Also, sometimes when charging or adding water, the murk in the sump gets stirred up and needs a day to settle back down.  Check it in the morning before charging stirs it up.
  • mcgivormcgivor Posts: 1,531Registered Users ✭✭✭✭
    Age of the battery is a factor, if the SG is fine it is probably as @mike95490 says, a cell fart, this can stir the sludge in the sump, have seen it happen, next day clear again, the plates are sacrificial which is why there is space below.
