How many watts do I need for my solar panel to have to power my tiny house?
SarahEfim
SarahEfim Registered Users Posts: 1
I am planning on running a small heater/AC (900 watts?), a small microwave (800 watts), a refrigerator (100 watts) and probably a light at some point. The refrigerator will be on 24/7 but the rest will be plugged in as needed, with the heater/AC running up to 12 hours at a time with 12 hour breaks. There may be other things here and there, but those will be my main energy-consumers. Any suggestions for solar panels?
  • Raj174
    Raj174 Solar Expert Posts: 795 ✭✭✭✭
    Hi SarahEfim,
    We need to have a rough idea where you are located to be able to make an approximation.
    BB. Super Moderators, Administrators Posts: 33,448 admin
    First guess is somewhere in the Asheville NC region...
    A refrigerator (full size Energy Star Rated) takes you to a medium size system:
    • 400 kWH per year / 365 days per year = 1.1 kWH = 1,100 WH per day
    The electric heater--If you run it 3 hours per day:
    • 900 Watts * 3 hours = 2,700 WH per day
    • 2,700 + 1,100 WH per day = 3,800 WH per day
    If you want 2 days of energy storage and 50% maximum battery discharge:
    • 3,800 WH per day * 1/0.85 AC inverter eff * 1/24 volt battery bank * 2 days storae * 1/0.50 max discharge = 745 AH @ 24 volt battery bank
    Or if you use "golf cart batteries" (6 volts @ 200 AH per battery) = 4x parallel strings of 4 batteries per string = 800 AH @ 24 volt battery bank.
    That is not a small battery bank (would probably suggest some other options, but it gives you a rough size of what such a battery bank would look like).
    An 800 AH @ 24 volt battery bank should be charged at 5% to 13% rate of charge, and if full time off grid, probably 10% or more rate of charge:
    • 800 AH * 29 volt charging * 1/0.77 panel+controller derating * 0.05 rate of charge = 1,506 Watt array minimum
    • 800 AH * 29 volt charging * 1/0.77 panel+controller derating * 0.05 rate of charge = 3,013 Watt array nominal
    • 800 AH * 29 volt charging * 1/0.77 panel+controller derating * 0.05 rate of charge = 3,917 Watt array "cost effective" maximum
    And then based on the hours of sun per day... Fixed array for Charlotte NC, tilted to winter power production (heater):
    Charlotte
    Measured in kWh/m2/day onto a solar panel set at a 40° angle from Vertical:
    (Optimal winter settings)
    Jan Feb Mar Apr May Jun
    3.79
    4.03
    4.75
    4.89
    4.66
    4.43
    Jul Aug Sep Oct Nov Dec
    4.46
    4.46
    4.57
    4.79
    4.14
    3.81
    Based on a minimum of 3.81 hours per day (December) of average sun:
    • 3,800 WH per day * 1/0.52 off grid system eff * 1/3.81 hours of sun December = 1,918 Watt array minimum (December "break even" solar power)
    There you go with a really quick guess at your power usage. In general, running electric heaters from solar electric panels is not really cost effective. You can make solar thermal panels (hot water or hot air) and do something better for heating. And, just having a full size refrigerator really makes the system much larger than one just supplying lights, cell phone and computer charging, and a 12 volt water pump.
    Using a Kill-a-Watt meter (or similar) can really help you understand your power needs and offer better guidance for design of your off grid power system.
    Your thoughts?
  • zoneblue
    As bills analysis shows the heater is going to be an issue. For a start you need heat when likely your sun is the least, so its not a good match for solar. Also most tiny houses wont have enough roof space, however if you really want to try to power all that, you could look at a stand alone shed for the batterys and a ground mount system. Still, your going to be into the 20K ball park budget wise, with the heater included. Without it maybe 10K. Suggest you look at other heat sources.
  • oil pan 4
    oil pan 4 Solar Expert Posts: 767 ✭✭✭✭
    How about forgetting about the electric heater and going with propane.
    Not attempting to power an electric heater purely on solar should give you at least several thousand to spend on a heater and there should be a few dollars left over to buy some propane.
    Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
    Solar roof top GMC suburban, a normal 3/4 ton suburban with 180 watts of panels on the roof and 10 amp genasun MPPT, 2000w samlex pure sine wave inverter, 12v gast and ARB air compressors.
  • Photowhit
    ...or heat with wood! there are more and  more, small wood heaters available. Learning bank them to burn long and low takes talent, I heated a camper with one. it will take some planning, but think about it now.
    Wire wood is carbon neutral! Particularly if you cut it with electric from your array!
    wood heating - http://www.inspirationgreen.com/masonry-heaters.html
    2/3 down look for "Mark Twain on the Kachelofen" quote.   Kachelofen are NOT rocket stoves
    An airtight wood stove banked down for an all night smoulder, emits a lot of air pollution.
  • Photowhit
    You are slowing the reaction, couldn't find where they had claimed it emitted more pollution.
    They do the math in this statement;
    "Wood is a renewable resource and absorbs CO2 as it grows. Burning releases about the same amount of carbon monoxide, carbon dioxide and methane as would occur if the wood were decomposing naturally on the forest floor."
  • vtmaps
    That's just plain wrong.  COMPLETE burning does not release carbon monoxide or methane.  Incomplete burning, such as smoldering all night in an airtight woodstove, can release all sorts of pollution that doesn't occur on the forest floor.
    --vtMaps
  • Photowhit
    Trees absorb Carbon gases as they grow, a smoldering fire will release more back into the atmosphere, but it can't create more. Carbon neutral...
    edited February 2016 #11
    here right near the top:
      Igniting and then drawing the heat out of the combustion gases turns almost every ounce of wood into energy. A slow burning, low temperature, low oxygen fire produces tar and hydrocarbons, a fast, hot, air-fed fire burns the pollutants up. Add a storage battery (the masonry) and you have a very efficient, non-polluting heating system. A metal stove gives out its heat rapidly, thus never allowing the inside combustion temperatures to achieve the 1100 degree F plus needed to ignite all the gases.
    The Tars and Hydrocarbons are the soot and smoke the EPA is concerned about. Metal stoves also emit carbon monoxide, The firebrick liner of masonry heaters reflect and contain a lot of heat inside the firebox, which becomes nearly incandescent white coals and is hot enough to burn and consume the CO and only emit CO2 and water vapor.  Only the beginning of the burn, when the heater is still cold, are there much emissions, and a top-down burn style gets rid of a lot of that too.
  • Photowhit
    I understand the EPA and the concerns in the 'Big City' We are truly infested with humans...
    I try to (I purchased a cord and a half this year) burn wood with in a few hundred feet of where they pulled the carbon gases out of the air. My trees don't mind the gases. my nearest neighbor is fin with it. Most metal stoves are lined with fire brick. It hasn't been above 32 outside for a few days, and my 'tin can' would not support (or at least is not designed to support a masonry stove. I have no problem with masonry stoves!
    BTW, the discussion centers on a Tiny house, most of which are built on wheels...
    I only have issues that burning wood in a smolder is somehow going to produce more carbon gases than it consumed in the creation, it's much like the hydrogen from water argument.
  • westbranch
    Whit, the issue is really that there is not any more CARBON in the equation it is what FORM the carbon is in, and TAR and CREOSOTE are just plain BAD for  humans!
    We burn wood, a lot of it  at the lake house in winter, cut  >dead  6 years and dried , if possible, for another year (summer season) or 2.  Minimal creosote in the stack after a year, < 3 cups per 20 + feet of insulated pipe, but lots of ash in the cook stove...
    West Chilcotin, BC, Canada
  • Photowhit
    I only burn a 2-3 cords over the winter, I have a straight drop and wanted to be sure to clean after 2 years often smoldering, and had very little in the way of particles. I've only pulled less than 2 'popcorn tins' of ash, perhaps 2 gallon size of ash out this year, I think less than 4 all winter last year.  If one heats with only flaming fires, often only the area around the stove is warm, as more air must be drawn in to maintain the fire.
    I have a stove that can be setup to draw combustion air from outside, but most are not designed this way. If I didn't smolder, I would be up every 4 hours feeding the fire, and be too hot or too cold often. This is the advantage of having a large thermal mass of a masonry stove. If I'm around, I will burn hot after feeding the fire before reducing the draft, this may reduce the build up.
  • zoneblue
    Hopefully those concerned about solid fuel stoves emssions, arent on grid using coal or nuclear for their home heating. Solid fuel is a time honored sustainable heating source with no where even remotely close, i mean orders of magnitude less, compared to some of the sheer stupidity modern man calls energy. That stuff has the potential to total the planet. For good.
  • Blindowl1234
    Blindowl1234 Registered Users Posts: 54 ✭✭
    This topic would go down in flames real quick where I live at lol. This morning it's 10 degrees out here in the country. Since probably every other house near us has a wood stove, my neighbors would say with gun in hand get off my land and stay out of my business. Man has been burning wood since he figured out how to lit it.
  • zoneblue
    Yeah well of course the rapid deforestion caused by early wood use particularly in the steel industry, isnt something we should be too proud of. Part of that can be attributed to the industrial revolution, part to the epic waste that is warfare, and the other part to overpopulation. Nothin in this life is simple.
