Need To Pump 1,600 Gal per Day
DanS26
Solar Expert Posts: 267 ✭✭✭
I currently use a 1,600 gal tank to gravity feed a drip irrigation system for my wife's extensive perennial garden. I fill this tank once a day using a small gasoline powered (Honda) pump.
I'd like to use a solar powered pump to fill this tank and thus would like to solicit suggestions from the members of this forum for a properly sized system for this application. The lift is approximately 20 ft., so I need a system to lift 1600 gallons 20 ft in about 6 hours (say 250 to 275 gals per hour). A float shut off would be nice also. This is not a pressurized system.
Thanks in advance for your advice.
23.16kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro System monitoring
Re: Need To Pump 1,600 Gal per Day
Fairly simple to design a system that's a stand alone for this. 5 Gallon a minute is easily obtainable with 2 panels, marginal with 1 tho. My demonstation model will produce 10 gallons a minute at that head on 2 panels, here's that setup.
Lorentz PS6000 controller
Lorentz 600HR motor
Lorentz HR14 Pump
You wouldn't need the PS600 controller, but it's not a lot more expensve than the PS200 and offers some advantages.
This system has the option of a float switch. -
I have a somewhat similar situation, about 2500 gallons, 160' lift, to supply a 300 tree orchard. I went with a standard well pump run off an inverter. Be glad you have such a low lift requirement, that saves a lot of power.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
